After a lot of tests and research, I think I found the way:
Add the follow at: "./includes/definitions/discovery/gaia.yaml"
oid: haStatCode
num_oid: '.1.3.6.1.4.1.2620.1.5.101.{{ $index }}'
descr: HA Status
group: HA
states:
- { value: 0, generic: 0, graph: 0, descr: OK }
- { value: 1, generic: 1, graph: 0, descr: 'Needs Atention' }
- { value: 2, generic: 2, graph: 0, descr: 'HA Down' }
Create the sensor state: "./includes/discovery/sensors/state/gaia.inc.php"
<?php
$states = [
['value' => 0, 'generic' => 0, 'graph' => 0, 'descr' => 'Active'],
['value' => 1, 'generic' => 3, 'graph' => 0, 'descr' => 'Standby'],
['value' => 2, 'generic' => 1, 'graph' => 0, 'descr' => 'Active Attention'],
['value' => 3, 'generic' => 2, 'graph' => 0, 'descr' => 'Down'],
$temp = snmpwalk_cache_multi_oid($device, 'haState', [], 'CHECKPOINT-MIB');
if (is_array($temp)) {
echo 'Gaia Cluster HA State: ';
//Create State Index
$state_name = 'haState';
create_state_index($state_name, $states);
foreach ($temp as $index => $data) {
//Convert string value to integer LibreNMS value
if ($currentstr == 'active') {
$value = 0;
if ($currentstr == 'standby') {
$value = 1;
if ($currentstr == 'Active Attention') {
$value = 2;
if ($currentstr == 'Down') {
$value = 3;
$descr = 'Cluster HA State';
$group = 'HA';
$current = $value;
$oid = '.1.3.6.1.4.1.2620.1.5.6.' . $index;
discover_sensor($valid['sensor'], 'state', $device, $oid, $index, $state_name, $descr, 1, 1, null, null, null, null, $current, 'snmp', $index, null, null, $group);
//Create Sensor To State Index
create_sensor_to_state_index($device, $state_name, $index);
} // End foreach (array_keys($temp) as $index)
} // End if (is_array($temp))
$states = [
['value' => 0, 'generic' => 3, 'graph' => 0, 'descr' => 'Disabled'],
['value' => 1, 'generic' => 0, 'graph' => 1, 'descr' => 'Enabled'],
$temp = snmpwalk_cache_multi_oid($device, 'fwSXLStat', [], 'CHECKPOINT-MIB');
echo 'SecureXL current status: ';
$state_name = 'fwSXLStat';
$descr = 'SecureXL current status';
$group = 'HA';
$current = $data['fwSXLStat'];
$oid = '.1.3.6.1.4.1.2620.1.36.1.1.' . $index;
Active Member:
Standby Member:
