[email protected]:/opt/librenms# ./discovery.php -h 10.84.17.2
LibreNMS Discovery
10.84.17.2 47 test-os
Load disco module os
Runtime for discovery module ‘os’: 0.1500 seconds with 840 bytes
Unload disco module os
Load disco module ports
Runtime for discovery module ‘ports’: 0.0550 seconds with 2184 bytes
Unload disco module ports
Load disco module ports-stack
Runtime for discovery module ‘ports-stack’: 0.0080 seconds with 640 bytes
Unload disco module ports-stack
Load disco module entity-physical
Caching OIDs: entPhysicalEntry entAliasMappingIdentifier…
Runtime for discovery module ‘entity-physical’: 0.5990 seconds with 4328 bytes
Unload disco module entity-physical
Load disco module processors
hrDevice: …
Runtime for discovery module ‘processors’: 0.6560 seconds with 46768 bytes
Unload disco module processors
Load disco module mempools
hrStorage : …
Runtime for discovery module ‘mempools’: 0.1390 seconds with 25832 bytes
Unload disco module mempools
Load disco module cisco-vrf-lite
Runtime for discovery module ‘cisco-vrf-lite’: 0.0000 seconds with 1592 bytes
Unload disco module cisco-vrf-lite
Module [ cisco-mac-accounting ] disabled globally.
Module [ cisco-pw ] disabled globally.
Module [ cisco-vrf ] disabled globally.
Module [ cisco-cef ] disabled globally.
Module [ cisco-sla ] disabled globally.
Module [ cisco-cbqos ] disabled globally.
Module [ cisco-otv ] disabled globally.
Load disco module ipv4-addresses
s.s.s.s.
Runtime for discovery module ‘ipv4-addresses’: 0.3080 seconds with 31136 bytes
Unload disco module ipv4-addresses
Load disco module ipv6-addresses
Runtime for discovery module ‘ipv6-addresses’: 0.1690 seconds with 17592 bytes
Unload disco module ipv6-addresses
Module [ route ] disabled globally.
Load disco module sensors
ENTITY-SENSOR: Caching OIDs: entPhysicalDescr entPhysicalName entPhySensorType entPhySensorScale entPhySensorPrecision entPhySensorValue…
Airflow:
Current:
Charge:
Dbm:
Fanspeed:
Frequency:
Humidity:
Load:
Power:
Runtime:
Signal:
State:
Temperature:
Voltage:
Snr:
Runtime for discovery module ‘sensors’: 1.2400 seconds with 73208 bytes
Unload disco module sensors
Load disco module storage
hrStorage : …
Runtime for discovery module ‘storage’: 0.3700 seconds with 7536 bytes
Unload disco module storage
Load disco module hr-device
Runtime for discovery module ‘hr-device’: 0.7380 seconds with 30304 bytes
Unload disco module hr-device
Load disco module discovery-protocols
CISCO-CDP-MIB: LLDP-MIB: OSPF Discovery: enabled
Runtime for discovery module ‘discovery-protocols’: 0.0630 seconds with 8568 bytes
Unload disco module discovery-protocols
Load disco module arp-table
eth0:
eth1:
eth2:
Runtime for discovery module ‘arp-table’: 0.0530 seconds with 45688 bytes
Unload disco module arp-table
Module [ discovery-arp ] disabled globally.
Module [ junose-atm-vp ] disabled globally.
Load disco module bgp-peers
No BGP on host
Runtime for discovery module ‘bgp-peers’: 0.0100 seconds with 2672 bytes
Unload disco module bgp-peers
Load disco module vlans
IEEE8021-Q-BRIDGE-MIB VLANs:
Runtime for discovery module ‘vlans’: 0.0460 seconds with 4456 bytes
Unload disco module vlans
Module [ vmware-vminfo ] disabled globally.
Module [ libvirt-vminfo ] disabled globally.
Module [ toner ] disabled globally.
Load disco module ucd-diskio
Runtime for discovery module ‘ucd-diskio’: 0.0390 seconds with 54656 bytes
Unload disco module ucd-diskio
Module [ applications ] disabled globally.
Load disco module services
Runtime for discovery module ‘services’: 0.0000 seconds with 352 bytes
Unload disco module services
Load disco module stp
Runtime for discovery module ‘stp’: 0.0130 seconds with 3648 bytes
Unload disco module stp
Load disco module ntp
Runtime for discovery module ‘ntp’: 0.0000 seconds with 144 bytes
Unload disco module ntp
Module [ loadbalancers ] disabled globally.
Module [ mef ] disabled globally.
Load disco module wireless
Runtime for discovery module ‘wireless’: 0.0080 seconds with 132808 bytes
Unload disco module wireless
Load disco module fdb-table
Runtime for discovery module ‘fdb-table’: 0.0430 seconds with 1016 bytes
Unload disco module fdb-table
Discovered in 5.162 seconds
SNMP: Get[19/0.28s] Walk [28/1.69s]
MySQL: Cell[122/0.09s] Row[22/-0.02s] Rows[55/0.03s] Column[1/0.00s] Update[92/2.30s] Insert[2/0.05s] Delete[0/0.00s]
