Help with Creating a New OS Definition
Hi everyone!
I’m a new user of LibreNMS. I have a network behavior management device that supports the SNMP protocol, which I tried to add to LibreNMS. After adding it, the system shows it as a generic Linux OS and fails to monitor the specific data I need. According to the official documentation Intro - LibreNMS Docs, custom operating system definitions should be possible.
I successfully added a new OS definition following the official guide, but for some reason, after some time, it reverts back to the default Linux status. It seems like the custom OS configuration isn’t persisting. Is there any additional configuration required to make it permanent? I’d appreciate your guidance.
New os file:
includes/definitions/sangfor-ac.yaml
os: sangfor-ac
text: 'Sangfor ac'
type: appliance
icon: sangfor-ac
group: sangfor
mib_dir: sangfor
over:
    - { graph: device_bits, text: 'Device Traffic' }
    - { graph: device_processor, text: 'CPU Usage' }
    - { graph: device_mempool, text: 'Memory Usage' }
discovery:
        sysObjectID:
            - .1.3.6.1.4.1.35047.2.1
        sysDescr_regex:
            - '/^Linux AC/
includes/definitions/discovery/sangfor-ac.yaml
mib: SANGFOR-GENERAL-MIB:SANGFOR-GENERAL-AND-SSL-MIB
modules:
   os:
     sysDescr_regex: '/Linux .*(?<ac>AC[\d.]+).*/'
     version: '.1.3.6.1.4.1.35047.2.1.1.7.0'
   mempools:
     data:
             free: SANGFOR-GENERAL-MIB::sfSysFreeMemoryNoUnit
             total: SANGFOR-GENERAL-MIB::sfSysTotalMemoryNoUnit
             descr: 'Free MeM'
             precision: 1
             type: sangfor-mem
   processors:
     data:
             oid: SANGFOR-GENERAL-MIB::sfSysCpuCostRate
             num_oid: '.1.3.6.1.4.1.35047.1.3.0'
             type: sangfor
             precision: 1
   sensors:
      count:
         data:
# user status
                oid: SANGFOR-GENERAL-MIB::statusinfo
                num_oid: '.1.3.6.1.4.1.35047.2.1.1.1.{{ $index }}'
                value: SANGFOR-GENERAL-MIB::numOfCurOnLine
                index: 'numOfCurOnLine.{{ $index }}'
                descr: 'online users'
                num_oid: '.1.3.6.1.4.1.35047.2.1.1.3.{{ $index }}'
                value: SANGFOR-GENERAL-MIB::numOfCurOU
                index: 'numOfCurOU.{{ $index }}'
                descr: 'Cur ORGS'
                value: SANGFOR-GENERAL-MIB::numOfSession
                num_oid: '.1.3.6.1.4.1.35047.2.1.1.6.{{ $index }}'
                index: 'numOfSession.{{ $index }}'
                descr: 'Sessions'
      state:
         data:
# AC status
               oid: SANGFOR-GENERAL-MIB::sfEnableDoubleHost
               num_oid: '.1.3.6.1.4.1.35047.1.7.{{ $index }}'
               descr: 'HA mode'
               group: 'AC STATUS'
               states:
                  - { value: 0, graph: 0, generic: 0, descr: disable}
                  - { value: 1, graph: 1, generic: 0, descr: enable}
event log
2025-03-03 20:02:17	system	192.168.1.101	OS Version: 13.0.62 -> 2.4.35.4-AC1.95	System
2025-03-03 20:02:17	system	192.168.1.101	Hardware: Generic x86	System
2025-03-03 20:02:17	system	192.168.1.101	Icon: images/os/generic.svg -> images/os/linux.svg	System
2025-03-03 20:02:17	processors	192.168.1.101	Processor Removed: sangfor 0 Processor	System
2025-03-03 20:02:16	system	192.168.1.101	Device type: appliance -> server	System
2025-03-03 20:02:16	system	192.168.1.101	Linux AC 2.4.35.4-AC1.95 #57 SMP ?? 10?? 20 18:47:21 CST 2009 i686 i686 i386 GNU/Linux -> Linux AC 2.4.35.4-AC1.95 #57 SMP ?? 10?? 20 18:47:21 CST 2009 i686 i686 i386 GNU/Linux	System
2025-03-03 20:02:16	system	192.168.1.101	Device OS changed: sangfor-ac -> linux	System
2025-03-03 20:02:16	system	192.168.1.101	Device OS: sangfor-ac -> linux	System
2025-03-03 14:42:16	system	192.168.1.101	Icon: images/os/generic.svg
2025-03-03 14:41:10	sensor	192.168.1.101	Sensor Added: state SANGFOR-GENERAL-MIB::sfEnableDoubleHost 0 HA mode	System
2025-03-03 14:41:10	sensor	192.168.1.101	Sensor Added: count sangfor-ac numOfCurOnLine.0 online users	System
2025-03-03 14:41:10	sensor	192.168.1.101	Sensor Added: count sangfor-ac numOfCurOU.0 Cur ORGS	System
2025-03-03 14:41:10	sensor	192.168.1.101	Sensor Added: count sangfor-ac numOfSession.0 Sessions	System
2025-03-03 14:41:09	processors	192.168.1.101	Processor Discovered: sangfor 0 Processor	System
2025-03-03 14:41:07	system	192.168.1.101	Linux AC 2.4.35.4-AC1.95 #57 SMP ?? 10?? 20 18:47:21 CST 2009 i686 i686 i386 GNU/Linux -> Linux AC 2.4.35.4-AC1.95 #57 SMP ?? 10?? 20 18:47:21 CST 2009 i686 i686 i386 GNU/Linux	System
2025-03-03 14:41:07	system	192.168.1.101	Device OS changed: linux -> sangfor-ac	System
2025-03-03 14:41:07	system	192.168.1.101	Device OS: linux -> sangfor-ac	System
2025-03-03 14:41:07	system	192.168.1.101	Device type: server -> appliance	System
2025-03-03 14:41:07	system	192.168.1.101	OS Version: 2.4.35.4-AC1.95 -> 13.0.62	System
2025-03-03 14:41:07	system	192.168.1.101	Hardware: Generic x86 ->	System
2025-03-03 14:41:07	system	192.168.1.101	Icon: images/os/linux.svg -> images/os/sangfor-ac.svg
/opt/librenms $ ./validate.php
LibreNMS  | 25.1.0 (2025-01-21T07:15:30+08:00)
DB Schema | 2024_11_22_135845_alert_log_refactor_indexes (310)
PHP       | 8.3.16
Python    | 3.12.8
Database  | MariaDB 10.11.10-MariaDB-ubu2204
RRDTool   | 1.9.0
SNMP      | 5.9.4
[OK]    Installed from the official Docker image; no Composer required
[OK]    No python wrapper pollers found
[OK]    Redis is functional
[OK]    rrd_dir is writable
[WARN]  Updates are managed through the official Docker image
thank you very much
Can you provide the output of sysObjectId and sysDescr. The yaml looks ok and the sysObjectId you are using doesn’t conflict so we’d need to see what they device is saying.
Thank you for your reply.
The device’s
sysObjectID  "SNMPv2-SMI::enterprises.35047.2.1"
sysDescr "Linux AC 2.4.35.4-AC1.95 #57 SMP ¶þ 10Ղ 20 18:47:21 CST 2009 i686 i686 i386 GNU/Linux"
Whenever I manually run discovery.php and poller.php, the configuration becomes effective temporarily. However, after a few hours, it reverts back to its original state. Could you please help diagnose this issue? Thank you. The relevant logs are attached below.
discovery.php https://p.libren.ms/view/135d3108
poller.php https://p.libren.ms/view/cbc10163
It looks like you’re running LibreNMS in docker. Not sure how your volumes are setup, is there any chance your new definitions are only on your librenms container but not your dispatcher container?
Thanks for the guidance! Just like you suggested, I placed the YAML file on the dispatcher container and it fixed the issue. Really appreciate your help!
I have another issue to discuss. My file system is custom and requires manually writing YAML configurations to retrieve partition names. I referenced vrp.yaml and created my own YAML file, but it fails to fetch the partition names. Whether I use pre-cache or variables like {{ $index }} , the system directly displays the variable name (e.g., sfFileSystemName.{{ $index }} appears as plain text). How can I resolve this?
   storage:
     pre-cache:
       data:
               oid:
                  - SANGFOR-GENERAL-MIB::sfFileSystemName
     data:
             oid: SANGFOR-GENERAL-MIB::sfDiskTable
             descr: sfFileSystemName
             type: sangfor-disk
             used: SANGFOR-GENERAL-MIB::sfDiskUsed
             percent_used: SANGFOR-GENERAL-MIB::sfDiskUsedPercent
             percent_used_num_oid: '.1.3.6.1.4.1.35047.1.5.1.6.{{ $index }}'
             units: 1048576
Updated data:
array (
  'storage_type' => 'sangfor-disk',
sfFileSystemName (sangfor-disk): 97%  725 MiB / 791 MiB
sfFileSystemName (sangfor-disk): 0%  0 B / 912 MiB
sfFileSystemName (sangfor-disk): 1%  4.5 MiB / 919 MiB
sfFileSystemName (sangfor-disk): 0%  0 B / 919 MiB
sfFileSystemName (sangfor-disk): 1%  3.6 MiB / 919 MiB
sfFileSystemName (sangfor-disk): 100%  61 MiB / 62 MiB
sfFileSystemName (sangfor-disk): 50%  50 MiB / 104 MiB
sfFileSystemName (sangfor-disk): 9%  22 MiB / 256 MiB
sfFileSystemName (sangfor-disk): 5%  39 MiB / 919 MiB
sfFileSystemName (sangfor-disk): 0%  0 B / 184 MiB
sfFileSystemName (sangfor-disk): 5%  3.5 MiB / 76 MiB
sfFileSystemName (sangfor-disk): 4%  2.4 MiB / 76 MiB
sfFileSystemName (sangfor-disk): 4%  2.2 MiB / 76 MiB
sfFileSystemName (sangfor-disk): 3%  1.8 MiB / 68 MiB
snmpwaik
SANGFOR-GENERAL-MIB::sfFilesystemName.1 = "/dev/sda1"
SANGFOR-GENERAL-MIB::sfFilesystemName.2 = "devtmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.3 = "tmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.4 = "tmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.5 = "tmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.6 = "/dev/sda6"
SANGFOR-GENERAL-MIB::sfFilesystemName.7 = "/dev/sda5"
SANGFOR-GENERAL-MIB::sfFilesystemName.8 = "tmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.9 = "tmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.10 = "tmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.11 = "/dev/sdb1"
SANGFOR-GENERAL-MIB::sfFilesystemName.12 = "/dev/sdb2"
SANGFOR-GENERAL-MIB::sfFilesystemName.13 = "/dev/sdb3"
SANGFOR-GENERAL-MIB::sfFilesystemName.14 = "/dev/sdb4"
You don’t need pre-cache, you need to use the full oid name in the yaml description: SANGFOR-GENERAL-MIB::sfFileSystemName
@murrant Thank you for your response. I’ve tried various methods—whether adding pre-cache, using SANGFOR-GENERAL-MIB::sfFileSystemName, or simply sfFileSystemName—but all return the literal variable name instead of the actual value. This issue has been persisting for a week and remains unresolved.
   storage:
     #pre-cache:
     #  data:
     #          oid:
     #             - SANGFOR-GENERAL-MIB::sfDiskTable
     data:
             descr: SANGFOR-GENERAL-MIB::sfFilesystemName
             units: 1048576
librenms:/opt/librenms# snmpwalk -v2c -c public -m mibs/sangfor/SANGFOR-GENERAL-AC-AD-MIB.mib 192.168.1.101 SANGFOR-GENERAL-MIB::sfFilesystemName
SANGFOR-GENERAL-MIB::sfFilesystemName.1 = STRING: "rootfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.2 = STRING: "udev"
SANGFOR-GENERAL-MIB::sfFilesystemName.3 = STRING: "/dev/sda2"
SANGFOR-GENERAL-MIB::sfFilesystemName.4 = STRING: "rc-svcdir"
SANGFOR-GENERAL-MIB::sfFilesystemName.5 = STRING: "shm"
SANGFOR-GENERAL-MIB::sfFilesystemName.6 = STRING: "/dev/sda1"
SANGFOR-GENERAL-MIB::sfFilesystemName.7 = STRING: "/dev/sda7"
SANGFOR-GENERAL-MIB::sfFilesystemName.8 = STRING: "/dev/sda6"
SANGFOR-GENERAL-MIB::sfFilesystemName.9 = STRING: "/dev/sda8"
SANGFOR-GENERAL-MIB::sfFilesystemName.10 = STRING: "/dev/sda5"
SANGFOR-GENERAL-MIB::sfFilesystemName.11 = STRING: "/dev/sdb1"
SANGFOR-GENERAL-MIB::sfFilesystemName.12 = STRING: "tmpfs"
SANGFOR-GENERAL-MIB::sfFilesystemName.13 = STRING: "tmpfs"
Post the output of a ./discovery.php -h HOSTNAME -d -m storage and lnms device:poll HOSTNAME -vv -m storage
Just check for any sensitive output
