I have recently installed librenms, and added a ubiquity edgeswitch.
However when i try to edit the .yaml definitions files, it does not seem to affect the way the device is displayed.
Do i need to reload the definitions files in any way? or should they update automatically?
Is there any way in the librenms GUI that i can check which .yaml file a device is using?
Please find the “edgeswitch.yaml” file below, the only change i made is changed type from “network” to “network_switch”.
Any help would be appreciated,
- Rafal Pilat
./validate.php:
| LibreNMS | 21.6.0-9-g1bb4dd173 |
| DB Schema | 2021_06_07_123600_create_sessions_table (211) |
| PHP | 7.4.3 |
| Python | 3.8.5 |
| MySQL | 10.3.29-MariaDB-0ubuntu0.20.04.1 |
| RRDTool | 1.7.2 |
| SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.1.3
[FAIL] You have no timezone set for php.
PHP: Runtime Configuration - Manual
./discovery.php
https://p.libren.ms/view/409ecea8
edgeswitch.yaml:
os: edgeswitch
text: EdgeSwitch
type: network_switch
icon: ubiquiti
ifname: true
bad_snmpEngineTime: true
over:
- { graph: device_bits, text: ‘Device Traffic’ }
- { graph: device_processor, text: ‘CPU Usage’ }
- { graph: device_mempool, text: ‘Memory Usage’ }
discovery:
sysObjectID:
- .1.3.6.1.4.1.4413
- .1.3.6.1.4.1.41112
- .1.3.6.1.4.1.10002
sysDescr_regex:
- ‘/^EdgeSwitch/’
- ‘/^EdgePoint/’
- ‘/^USW[ -]/’
- ‘/^UBNT US/’
- ‘/^US[ -]/’
sysObjectID:
- .1.3.6.1.4.1.8072.3.2.10
- .1.3.6.1.4.1.27282.3.2.10
sysDescr_regex:
- ‘/^Linux UBNT/’
- ‘/^RTL8380/’
