Help with snmp-scan.py
Hi , need help setting up a cronjob for running the snmp-scan script , so far i tried:
*/1 * * * * librenms /opt/librenms/snmp-scan.py >> /var/log/snmpdiscovery.log 2>&1
This gives a error: /usr/bin/env: ‘lnms’: No such file or directory
Running the script manually with librenms user works with no problems:
librenms@linuxhost:~$ ./snmp-scan.py
Scanning IPs:
Scanned 62 IPs: 60 known devices, added 0 devices, failed to add 0 devices
Runtime: 3.50 seconds
Run validate.php and fix the problems
There seem to be no problems, only the script , i put some comments miself.
librenms@linuxhost:~$ php validate.php
LibreNMS 22.6.0-29-ga9d5c378f
DB Schema 2022_05_30_084932_update-app-status-length (242)
PHP 7.4.28
Python 3.9.2
MySQL 10.5.15-MariaDB-0+deb11u1
SNMP 5.9
[OK] Composer Version: 2.3.9
[OK]
[OK] MySQl and PHP time match
Modified Files:
rrd/.gitignore
snmp-scan.py
Managed to get in working by switching to crontab , i has using the librenms file under cron.d
