I am having trouble creating a custom alert. This is mostly due to my lack of SQL knowledge really.
Basically, I want to create an alert that triggers when a value is more than 80% of 2 combined values.
These values are in the application_metrics table and are names df_RBD-EC_avail and df_rbd_used. There 2 values combined give the total available space of the pool.
MariaDB [librenms]> select * FROM application_metrics;
| app_id | metric | value | value_prev |
| 3 | df_c_avail | 611228288139260 | 611228288139260 |
| 3 | df_c_objects | 257507844161540 | 257508722933760 |
| 3 | df_c_used | 353183724388350 | 353183009521660 |
| 3 | df_device_health_metrics_avail | 52133420335104 | 52133671993344 |
| 3 | df_device_health_metrics_objects | 44 | 41 |
| 3 | df_device_health_metrics_used | 338827006 | 336683607 |
| 3 | df_rbd_avail | 52133420335104 | 52133671993344 |
| 3 | df_rbd_objects | 45 | 47 |
| 3 | df_rbd_used | 144364335 | 136079123 |
| 3 | df_RBD-EC_avail | 104266840670210 | 104267343986690 |
| 3 | df_RBD-EC_objects | 46965069 | 46965067 |
| 3 | df_RBD-EC_used | 349948280250140 | 349947543691030 |
| 3 | osd_osd.0_apply_ms | 12 | 40 |
| 3 | osd_osd.0_commit_ms | 12 | 40 |
| 3 | osd_osd.1_apply_ms | 3 | 1 |
| 3 | osd_osd.1_commit_ms | 3 | 1 |
The current value would be 454215120920350 (104266840670210 + 349948280250140).
I could build a query with a static value but I don’t want to have to change it every time the pool grows in size.
Here the current rule the I have:
Like I said, I could manually input the threshold value but I’d prefer it to be more dynamic and adjust with the pool size.
How can I make the alert trigger when application_metrics.value is less than ((df_RBD-EC_avail + df_RBD-EC_used) * 0.80)? I am sorry if this does not make much sense but I essentially was trying to represent 80% of these 2 values.
Thank you
