Trying to fix an issue where some (4) HPE switches are reporting High CPU usage (>80%), when I verify with show system info on switch, the CPU utilization is <10%.
And when i use snmpget from the same librenms server with same OID, I get <10.
From debug:
Attempting to initialize OS: procurve
OS initilized as Generic
SQL[SELECT * FROM processors WHERE device_id=? [90] 0.74ms]
[OK] Composer Version: 1.8.0
[WARN] Your install is over 24 hours out of date, last update: Wed, 09 Jan 2019 12:29:22 +0000
A reason might be the polling itself. Depending on how the switch calculates the CPU usage (instant or averaged) the high amount of snmp requests is in fact creating a peak at each and every poll. So the librenms graph will show 80% flat whereas the real graph should be 80% peak at each poll and 10% average the rest of the time.
Unfortunately, there is no easy way to avoid this bias. And the peak load is a real peak of CPU usage so it is stil interesting to know it happened …
Are they the same model. May be they have a less powerfull CPU and get more stress from the SNMP polls ? May be they have more ports and get more stress from the SNMP polls … etc etc.
I have this issue on some devices, and even on fairly expensives Cisco chassis … It really depends how the SNMP replies are prioritized in the OS of the device, and how the CPU usage is calculated.
Same model, same port count, same OS version, etc.
From reviewing the historic graphs for CPU usage, it seems that it happen after upgrading from 1.3x to 1.4x a couple months back.
Not sure which version was on before, but I have only one server that was upgraded a couple months back. So all the discovery and poller modules will be the same.
I mean on the devices, you can enable/disable modules. Do they all have the same modules activated ?
Sometimes the device has its SNMP code crashed in some way. If you have an opportunity to reload one of the 4 culprits, you can also try that …
In /opt/librenms (or wherever you installed LibreNMS):
./discovery.php -h xxx
(with xxx being the device id)
You can add “-v” for verbosity and “-d” for debug.
Default values are visible from the GUI (in the “module” list of the device)
nope… was going to upgrade the 3800 firmware on the stack with this issue, I don’t have a change window to do so yet. Just wondering which version / switch you have this issue.
Same here, it’s only a 3800 stack which seems to be affected, both 15.18.0013 and 16.02.0022m.
We came from 15.12.0010 which didn’t seem to have the issue, but I haven’t gone back as it’s one of our core switches.
It’s weird as if you query the OID 1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0 it shows the correct value, and running a debug discovery as above seems to suggest that it’s getting it’s data from there.
Discovered LibreNMS\Device\Processor Array
[processor_id] =>
[entPhysicalIndex] => 0
[hrDeviceIndex] => 0
[device_id] => 163
[processor_oid] => .1.3.6.1.4.1.11.2.14.11.5.1.9.6.1.0
[processor_index] => 0
[processor_type] => procurve-fixed
[processor_usage] => 9
[processor_descr] => Processor
[processor_precision] => 1
[processor_perc_warn] => 75
SQL[SELECT * FROM processors WHERE device_id=? AND processor_index=? AND processor_type=? [163,“0”,“procurve-fixed”] 0.47ms]
.SQL[SELECT * FROM processors WHERE device_id=? AND processor_index=? AND processor_type=? [163,“0”,“procurve-fixed”] 0.33ms]
.SQL[SELECT * FROM processors WHERE device_id=? AND processor_id NOT IN (?,?) [163,73,73] 0.29ms]
SQL[DELETE T FROM processors T LEFT JOIN devices ON devices.device_id = T.device_id WHERE devices.device_id IS NULL 0.53ms]
Runtime for discovery module ‘processors’: 15.1600 seconds with 486480 bytes
SNMP: [5/14.95s] MySQL: [4/0.00s] RRD: [0/0.00s]
I have 3800 stacks that don’t have the issue and a few stacks that do. I don’t think it’s a switch firmware issue. I start seeing this after I upgraded LibreNMS. All my 3800 stacks are on 16.02.0020
