Hi Everyone,
How LibreNms to configure for check two WAN port. If the main connection down and LiberNms start monitoring. failover connection and notifying us. Check the Picture below:
Hi Everyone,
Your librenms server is onside the lan?
Or is your wan 2 same ip(device) address for polling?
Then u can make allert rules,
Else u need to make an vpn to your libre server, so whenn wan 3 go down, and wan 2 go active, the vpn will kick in and can poll same ip(device) again, and u need to make allert rules for it.
HI Team,
I got the notification about the router is down, but 4G failover is working.
How I can get the WAN3 is reporting back to the server?
Can post the alert rule you made or you are using.
Hi Kevin,
I am new to Librenms.
I am using the default setting.
It showing same External IP on WAN2 and WAN3.
I don’t know how to tell librenms to give correct external IP address on WAN3.
