How do I contribute my os yaml and php files?
I didn’t set up the test environment before hand and have the system up and running.
I’ve added yaml and php files for Lantronix/Transition switches and Bosh IP Cameras.
The system is isolated from the internet for the most part.
Thanks.
Follow the docs to set up a dev environment on your local computer.
Then copy the files into that and contribute from there.
