How can I edit “Right here, right now” ?
I tryed “edit” button (at the right) but it’s for the map, not the name.
Thank you in advance
You can override syslocation in the device edit page.
but there are 50 devices
If they are exactly the same, you can MAP them https://docs.librenms.org/Support/Configuration/#location-mapping
yes they are the same
but I need to change location name for 50 devices only once
But if the actual location of those devices are the same, you can map that location to be another.
any sugestion ?
