Hello @denis
These ports are ports that, before being considered “failed”, you must verify that they actually have active devices connected to them.
If the port is not in an active link with a remote host, it will appear as down, and this is normal.
Regards
Hello @aleferrari
The whole problem is that I uploaded customized mibs for the respective devices that made it possible to raise all those ports that are down. That’s why I’m interested in this problem because I think that those ports should be separated according to the mibs of the respective device.
Regards
