We’ve got 50 or so Tycon TPDIN power controllers on our network. I see that librenms has a MIB for the newer version of this device, but not the v1 that we’re using. I’ve downloaded the v1 MIB from Tycon, here:
http://tyconsystems.com/Assets/TPDIN%20Firmware/SNMP%20MIB%20File.txt
The OID is: http://tyconsystems.com/Assets/TPDIN%20Firmware/OID%20File.txt
I’ve copied the v1 MIB file to /opt/librenms/mibs/tycon/TPDIN1-MIB
…and enabled MIB polling in one of the device modules. But the device MIB doesn’t seem to be recognized by librenms. Here’s the output of ./discovery.php -d -h 355 >/tmp/tycon_debug.txt
LibreNMS Discovery
Version info:
Commit SHA: afa5b6fd00acd2e9ec62aaa4bd88c7448aa9fe62
Commit Date: 1501531269
DB Schema: 200
PHP: 7.0.18-0ubuntu0.16.04.1
MySQL: 5.7.19-0ubuntu0.16.04.1
RRDTool: 1.7.0
SNMP: NET-SNMP 5.7.3
SQL[e[0;33mSELECT * FROM devices
WHERE status = 1 AND disabled = 0 AND device_id
= ‘355’ ORDER BY device_id DESCe[0m]
SQL[e[0;33mSELECT * FROM devices_attribs WHERE device_id
= '355’e[0m]
172.16.10.23 355 generic SQL[e[0;33mINSERT INTO device_perf
(xmt
,rcv
,loss
,min
,max
,avg
,device_id
,timestamp
) VALUES (‘3’,‘3’,‘0’,‘9.20’,‘17.2’,‘11.9’,‘355’,NOW())e[0m]
SNMP Check response code: 0
SNMP[e[0;36m/usr/bin/snmpget -v2c -c COMMUNITY -Ovq -M /opt/librenms/mibs udp:HOSTNAME:161 SNMPv2-MIB::sysDescr.0e[0m]
No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpget -v2c -c COMMUNITY -Ovqn -M /opt/librenms/mibs udp:HOSTNAME:161 SNMPv2-MIB::sysObjectID.0e[0m]
.*.4.1.17095
| | .1.3.6.1.4.1.17095 |
SNMP[e[0;36m/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -M /opt/librenms/mibs udp:HOSTNAME:161 SML-MIB::product-Name.0e[0m]
Modules status: Global+ OS Device
Load disco module os
.*.4.1.17095
Runtime for discovery module ‘os’: 0.2470 seconds with 1168 bytes
Unload disco module os
Load disco module ports
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ifDescre[0m]
ifDescr.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ifNamee[0m]
ifName.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ifAliase[0m]
ifAlias.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m IF-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ifTypee[0m]
ifType.0 = No Such Object available on this agent at this OID
Array
SQL[e[0;33mSELECT name
FROM port_association_mode
WHERE pom_id = '1’e[0m]
SQL[e[0;33mSELECT * FROM ports
WHERE device_id
= ‘355’ ORDER BY port_ide[0m]
Runtime for discovery module ‘ports’: 0.3640 seconds with 1768 bytes
Unload disco module ports
Load disco module ports-stack
SQL[e[0;33mSELECT * FROM ports_stack
WHERE device_id
= '355’e[0m]
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -M /opt/librenms/mibs udp:HOSTNAME:161 ifStackStatuse[0m]
Runtime for discovery module ‘ports-stack’: 0.0110 seconds with 640 bytes
Unload disco module ports-stack
Load disco module entity-physical
Caching OIDs: entPhysicalEntrySNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-MIB:CISCO-ENTITY-VENDORTYPE-OID-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entPhysicalEntrye[0m]
entPhysicalEntry.0 = No Such Object available on this agent at this OID
entAliasMappingIdentifierSNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-MIB:IF-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entAliasMappingIdentifiere[0m]
entAliasMappingIdentifier.0 = No Such Object available on this agent at this OID
SQL[e[0;33mSELECT * FROM entPhysical
WHERE device_id
= '355’e[0m]
Runtime for discovery module ‘entity-physical’: 0.2040 seconds with 2928 bytes
Unload disco module entity-physical
Load disco module processors
hrDevice: SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES -M /opt/librenms/mibs udp:HOSTNAME:161 hrDevicee[0m]
hrDevice.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES -M /opt/librenms/mibs udp:HOSTNAME:161 hrProcessorLoade[0m]
hrProcessorLoad.0 = No Such Object available on this agent at this OID
SQL[e[0;33mSELECT COUNT(*) FROM processors
WHERE device_id
= ‘355’ AND processor_type
!= 'ucd-old’e[0m]
SQL[e[0;33mSELECT * FROM processors
WHERE device_id
= '355’e[0m]
Runtime for discovery module ‘processors’: 0.1930 seconds with 45112 bytes
Unload disco module processors
Load disco module mempools
SQL[e[0;33mSELECT COUNT(*) FROM mempools
WHERE device_id
= ‘355’ AND mempool_type
= 'cemp’e[0m]
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m NETSWITCH-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/hp udp:HOSTNAME:161 hpLocale[0m]
hpLocalMem.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m NETSWITCH-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/hp udp:HOSTNAME:161 hpGlobale[0m]
hpGlobalMem.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES:NetWare-Host-Ext-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 hrStorageEntrye[0m]
hrStorageEntry.0 = No Such Object available on this agent at this OID
SQL[e[0;33mSELECT * FROM mempools
WHERE device_id
= '355’e[0m]
Runtime for discovery module ‘mempools’: 0.4490 seconds with 16536 bytes
Unload disco module mempools
Load disco module cisco-vrf-lite
SQL[e[0;33mSELECT * FROM vrf_lite_cisco WHERE device_id = ‘355’ e[0m]
Runtime for discovery module ‘cisco-vrf-lite’: 0.0010 seconds with 1544 bytes
Unload disco module cisco-vrf-lite
Modules status: Global- OS Device Module [ cisco-mac-accounting ] disabled globally.
Modules status: Global- OS Device Module [ cisco-pw ] disabled globally.
Modules status: Global- OS Device Module [ cisco-vrf ] disabled globally.
Modules status: Global- OS Device Module [ cisco-cef ] disabled globally.
Modules status: Global- OS Device Module [ cisco-sla ] disabled globally.
Modules status: Global- OS Device Module [ cisco-cbqos ] disabled globally.
Modules status: Global- OS Device Module [ cisco-otv ] disabled globally.
Load disco module ipv4-addresses
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Osq -m IP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ipAdEntIfIndexe[0m]
ipAdEntIfIndex.0 No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m IP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ipAdEntNetMask.e[0m]
SQL[e[0;33mSELECT COUNT() FROM ports
WHERE device_id = ‘355’ AND ifIndex
= ''e[0m]
!SQL[e[0;33mSELECT ipv4_addresses
., ports
.device_id
, ports
.ifIndex
FROM ipv4_addresses
LEFT JOIN ports
ON ipv4_addresses
.port_id
= ports
.port_id
WHERE ports
.device_id = ‘355’ OR ports
.device_id
IS NULLe[0m]
Runtime for discovery module ‘ipv4-addresses’: 0.1220 seconds with 10888 bytes
Unload disco module ipv4-addresses
Load disco module ipv6-addresses
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Ln -Osq -m IP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ipAddressIfIndex.ipv6e[0m]
ipAddressIfIndex.ipv6."" No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Ln -Osq -OnU -m IPV6-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ipv6AddrPfxLengthe[0m]
...* No Such Object available on this agent at this OID
SQL[e[0;33mSELECT ipv6_addresses
.*, ports
.device_id
, ports
.ifIndex
FROM ipv6_addresses
LEFT JOIN ports
ON ipv6_addresses
.port_id
= ports
.port_id
WHERE ports
.device_id
IS NULLe[0m]
Runtime for discovery module ‘ipv6-addresses’: 0.1890 seconds with 1216 bytes
Unload disco module ipv6-addresses
Modules status: Global- OS Device Module [ route ] disabled globally.
Load disco module sensors
ENTITY-SENSOR: Caching OIDs: entPhysicalDescrSNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m CISCO-ENTITY-SENSOR-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entPhysicalDescre[0m]
entPhysicalDescr.0 = No Such Object available on this agent at this OID
entPhysicalNameSNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m CISCO-ENTITY-SENSOR-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entPhysicalNamee[0m]
entPhysicalName.0 = No Such Object available on this agent at this OID
entPhySensorTypeSNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entPhySensorTypee[0m]
entPhySensorType.0 = No Such Object available on this agent at this OID
entPhySensorScaleSNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entPhySensorScalee[0m]
entPhySensorScale.0 = No Such Object available on this agent at this OID
entPhySensorPrecisionSNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entPhySensorPrecisione[0m]
entPhySensorPrecision.0 = No Such Object available on this agent at this OID
entPhySensorValueSNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m ENTITY-SENSOR-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 entPhySensorValuee[0m]
entPhySensorValue.0 = No Such Object available on this agent at this OID
SQL[e[0;33mSELECT attrib_value FROM devices_attribs WHERE device_id
= ‘355’ AND attrib_type
= ‘ipmi_hostname’ e[0m]
SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘voltage’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'ipmi’e[0m]
SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘temperature’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'ipmi’e[0m]
SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘fanspeed’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'ipmi’e[0m]
SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘power’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'ipmi’e[0m]
Airflow: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘airflow’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Current: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘current’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Charge: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘charge’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Dbm: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘dbm’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Fanspeed: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘fanspeed’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Frequency: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘frequency’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Humidity: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘humidity’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Load: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘load’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Power: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘power’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Runtime: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘runtime’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Signal: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘signal’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
State: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘state’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Temperature: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘temperature’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Voltage: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘voltage’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Snr: SQL[e[0;33mSELECT * FROM sensors AS S, devices AS D WHERE S.sensor_class=‘snr’ AND S.device_id = D.device_id AND D.device_id = ‘355’ AND S.poller_type = 'snmp’e[0m]
Runtime for discovery module ‘sensors’: 0.6710 seconds with 13424 bytes
Unload disco module sensors
Load disco module storage
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m EQLVOLUME-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/equallogic udp:HOSTNAME:161 EqliscsiVolumeEntrye[0m]
eqliscsiVolumeEntry.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m NETAPP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 dfEntrye[0m]
dfEntry.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m UCD-SNMP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 dskTablee[0m]
dskTable.0 = No Such Object available on this agent at this OID
SQL[e[0;33mSELECT storage_descr
FROM storage
WHERE device_id
= ‘355’ AND storage_type
!= 'dsk’e[0m]
SQL[e[0;33mSELECT * FROM storage
WHERE device_id
= '355’e[0m]
Runtime for discovery module ‘storage’: 0.5090 seconds with 3232 bytes
Unload disco module storage
Load disco module hr-device
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES -M /opt/librenms/mibs udp:HOSTNAME:161 hrDeviceEntrye[0m]
hrDeviceEntry.0 = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m HOST-RESOURCES-MIB:HOST-RESOURCES-TYPES -M /opt/librenms/mibs udp:HOSTNAME:161 hrProcessorEntrye[0m]
hrProcessorEntry.0 = No Such Object available on this agent at this OID
Array
SQL[e[0;33mSELECT * FROM hrDevice
WHERE device_id
= '355’e[0m]
Runtime for discovery module ‘hr-device’: 0.2940 seconds with 832 bytes
Unload disco module hr-device
Load disco module discovery-protocols
CISCO-CDP-MIB: SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m CISCO-CDP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 cdpCachee[0m]
cdpCache.0 = No Such Object available on this agent at this OID
Array
LLDP-MIB: SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m LLDP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 lldpRemoteSystemsDatae[0m]
Array
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m BRIDGE-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 dot1dBasePortIfIndexe[0m]
dot1dBasePortIfIndex.0 = No Such Object available on this agent at this OID
Array
OSPF Discovery: enabled
SQL[e[0;33mSELECT DISTINCT(ospfNbrIpAddr
),device_id
FROM ospf_nbrs
WHERE device_id
='355’e[0m]
SQL[e[0;33mSELECT * FROM links
AS L, ports
AS I WHERE L.local_port_id = I.port_id AND I.device_id = '355’e[0m]
Runtime for discovery module ‘discovery-protocols’: 6.2450 seconds with 4064 bytes
Unload disco module discovery-protocols
Load disco module arp-table
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUsetX -m IP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ipNetToPhysicalPhysAddresse[0m]
ipNetToPhysicalPhysAddress[0] = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUsetX -m IP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 ipNetToMediaPhysAddresse[0m]
ipNetToMediaPhysAddress[0] = No Such Object available on this agent at this OID
SQL[e[0;33mSELECT * from ipv4_mac
WHERE device_id
=‘355’ AND context_name
=’'e[0m]
SQL[e[0;33mDELETE ipv4_mac
FROM ipv4_mac
LEFT JOIN ports
ON ipv4_mac
.port_id
= ports
.port_id
LEFT JOIN devices
ON ipv4_mac
.device_id
= devices
.device_id
WHERE ports
.port_id
IS NULL OR devices
.device_id
IS NULLe[0m]
Runtime for discovery module ‘arp-table’: 0.1920 seconds with 1376 bytes
Unload disco module arp-table
Modules status: Global- OS Device Module [ discovery-arp ] disabled globally.
Modules status: Global- OS Device Module [ junose-atm-vp ] disabled globally.
Load disco module bgp-peers
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -Oqvn -M /opt/librenms/mibs udp:HOSTNAME:161 .1.3.6.1.2.1.15.2e[0m]
No BGP on hostPeers :
SQL[e[0;33mSELECT * FROM bgpPeers WHERE device_id = ‘355’ AND (context_name = ‘’ OR context_name IS NULL)e[0m]
Runtime for discovery module ‘bgp-peers’: 0.0870 seconds with 2768 bytes
Unload disco module bgp-peers
Load disco module vlans
SQL[e[0;33mSELECT * FROM vlans
WHERE device_id
= '355’e[0m]
IEEE8021-Q-BRIDGE-MIB VLANs: SNMP[e[0;36m/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m IEEE8021-Q-BRIDGE-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 dot1qVlanVersionNumber.0e[0m]
Runtime for discovery module ‘vlans’: 0.1340 seconds with 4384 bytes
Unload disco module vlans
Modules status: Global- OS Device Module [ vmware-vminfo ] disabled globally.
Modules status: Global- OS Device Module [ libvirt-vminfo ] disabled globally.
Modules status: Global- OS Device Module [ toner ] disabled globally.
Load disco module ucd-diskio
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUs -m UCD-DISKIO-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 diskIOEntrye[0m]
diskIOEntry.0 = No Such Object available on this agent at this OID
Array
SQL[e[0;33mSELECT * FROM ucd_diskio
where device_id
= '355’e[0m]
Runtime for discovery module ‘ucd-diskio’: 0.1150 seconds with 736 bytes
Unload disco module ucd-diskio
Modules status: Global- OS Device Module [ applications ] disabled globally.
Load disco module services
Runtime for discovery module ‘services’: 0.0000 seconds with 328 bytes
Unload disco module services
Load disco module stp
SQL[e[0;33mSELECT * FROM stp
WHERE device_id
= '355’e[0m]
SNMP[e[0;36m/usr/bin/snmpget -v2c -c COMMUNITY -Oqv -m RSTP-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 dot1dStpProtocolSpecification.0e[0m]
Runtime for discovery module ‘stp’: 0.0280 seconds with 3648 bytes
Unload disco module stp
Load disco module ntp
Runtime for discovery module ‘ntp’: 0.0000 seconds with 144 bytes
Unload disco module ntp
Modules status: Global- OS Device Module [ loadbalancers ] disabled globally.
Modules status: Global- OS Device Module [ mef ] disabled globally.
Load disco module wireless
Attempting to initialize OS: generic
OS initialized: LibreNMS\OS\Generic
SQL[e[0;33mSELECT * FROM wireless_sensors
WHERE device_id
=‘355’ AND sensor_class
='ap-count’e[0m]
WHERE device_id
='clients’e[0m]
WHERE device_id
='quality’e[0m]
WHERE device_id
='capacity’e[0m]
WHERE device_id
='utilization’e[0m]
WHERE device_id
='rate’e[0m]
WHERE device_id
='ccq’e[0m]
WHERE device_id
='snr’e[0m]
WHERE device_id
='mse’e[0m]
WHERE device_id
='rssi’e[0m]
WHERE device_id
='power’e[0m]
WHERE device_id
='noise-floor’e[0m]
WHERE device_id
='error-ratio’e[0m]
WHERE device_id
='error-rate’e[0m]
WHERE device_id
='frequency’e[0m]
WHERE device_id
='distance’e[0m]
Runtime for discovery module ‘wireless’: 0.0240 seconds with 198384 bytes
Unload disco module wireless
Load disco module fdb-table
SQL[e[0;33mSELECT vlan_id
, vlan_vlan
from vlans
WHERE device_id
= '355’e[0m]
SQL[e[0;33mSELECT * FROM ports_fdb
WHERE device_id
= '355’e[0m]
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUsetX -m Q-BRIDGE-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 dot1qTpFdbPorte[0m]
dot1qTpFdbPort[0] = No Such Object available on this agent at this OID
SNMP[e[0;36m/usr/bin/snmpbulkwalk -v2c -c COMMUNITY -OQUsetX -m BRIDGE-MIB -M /opt/librenms/mibs udp:HOSTNAME:161 dot1dTpFdbPorte[0m]
dot1dTpFdbPort[.0 = No Such Object available on this agent at this OID
Runtime for discovery module ‘fdb-table’: 0.3010 seconds with 1872 bytes
Unload disco module fdb-table
= ‘poll_mib’ e[0m]
= ‘poll_mib’ e[0m]
MIB: registering
SNMP[e[0;36msnmptranslate -M /opt/librenms/mibs -IR -m all enterprises.17095 2>/dev/nulle[0m]
RFC1155-SMI::enterprises.17095
SNMP translated: all::enterprises.17095 -> RFC1155-SMI::enterprises.17095
Array
MIB: Could not load definition for RFC1155-SMI::enterprises.17095
SQL[e[0;33mUPDATE devices
set last_discovered
=NOW(),last_discovered_timetaken
=‘11.71’ WHERE device_id
= '355’e[0m]
Discovered in 11.71 seconds
SQL[e[0;33mINSERT INTO perf_times
(type
,doing
,start
,duration
,devices
,poller
) VALUES (‘discover’,‘355’,‘1501614342.5681’,‘11.78’,‘1’,‘librenmsbox\n’)e[0m]
./discovery.php 355 2017-08-01 13:05:54 - 1 devices discovered in 11.78 secs
SNMP: Get[10/0.29s] Walk [29/3.20s]
MySQL: Cell[5/0.00s] Row[5/0.00s] Rows[57/0.05s] Column[1/0.00s] Update[1/0.00s] Insert[2/0.00s] Delete[0/0.00s]
