Dear All,
How to another device Modem Satellite: Hughes,Newtec and Shiron to Monitoring snmp on LibreNMS
I’m using Ubuntu Server 18.
Dear All,
Do those devices support SNMP?
Yes Kevin,
Modem satellite support snmp
snmp community =public or private and v1
[email protected]:/opt/librenms# ./addhost.php 10.17.153.129 v1 161 udp
Could not ping 10.17.153.129
[email protected]:/opt/librenms# ping 10.17.153.129
PING 10.17.153.129 (10.17.153.129) 56(84) bytes of data.
64 bytes from 10.17.153.129: icmp_seq=1 ttl=62 time=539 ms
64 bytes from 10.17.153.129: icmp_seq=2 ttl=62 time=540 ms
64 bytes from 10.17.153.129: icmp_seq=3 ttl=62 time=524 ms
^C
— 10.17.153.129 ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2001ms
rtt min/avg/max/mdev = 524.363/534.919/540.485/7.515 ms
i can ping and reply Could not ping 10.17.153.129
any idea kevin? please help
but result is:
You don’t have to add by cli try with the web ui
@Hill_A_Damanik
It seems that you are user root on the CLI. This is not supposed to happen. LibreNMS must be run as librenms user. Using root is usually breaking things (permissions).
I would suggest to log as “librenms” user, run ./validate.php
and check that no errors are discovered.
Then add you device via the web GUI.
Dear Pipo,
i already run to libre:
[email protected]:/opt/librenms# snmpwalk -c “private” -v1 “10.17.153.129”
Timeout: No Response from 10.17.153.129
but not respon
and this result .validate.php
Component | Version |
LibreNMS | 1.58.1-32-gb2137787f |
DB Schema | 2019_10_03_211702_serialize_config (147) |
PHP | 7.3.12-1+ubuntu18.04.1+deb.sury.org+1 |
MySQL | 10.1.43-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.9.1
[FAIL] You have no timezone set for php.
http://php.net/manual/en/datetime.configuration.php#ini.date.timezone
[WARN] Your install is over 24 hours out of date, last update: Sat, 14 Dec 2019 01:24:53 +0000
Modified Files:
.codeclimate.yml
.editorconfig
.env.dusk.testing
.env.example
.github/ISSUE_TEMPLATE.md
.github/ISSUE_TEMPLATE/New-Device.md
.github/PULL_REQUEST_TEMPLATE.md
.github/ci-reporter.yml
.github/label-actions.yml
.github/lock.yml
.github/no-response.yml
.github/stale.yml
.gitignore
.mention-bot
.scrutinizer.yml
and 10427 more…
You are running all your tests with the “root” user. That is not correct. You must be running as “librenms” user.
Moreover, you validate shows a huge amount of issues, cron jobs are not running, updates are not running, timezone is not set etc etc.
You should start by fixing these (or, may be, by re-installing LibreNMS following the docs to get the correct setup).
Concerning SNMP, the snmpwalk command looks theoretically good for a device doing snmp v1 with community private. If you don’t get an answer here, check the routing and firewalls in between (if any). Check the config of the device to ensure that no access lists are configured for SNMP for each community. “private” being the RW community, you should probably stick with “public” community by the way.
Dear Pipo,
Thank’s for your explain.
but please way to i’m running to “librenms”.
and ./validate.php please help this error
LibreNMS | 1.58.1-33-g5bf56db50 |
RRDTool | 1.7.0 |
because i’m already try way from this community but still error.
Hi
To run as “librenms”, like always on Linux, login as “librenms” to the machine, and not as “root”.
If you are root, you can type su - librenms
to switch to “librenms” user. Then run again ./validate.php and fix all the issues you’ll get.
Concerning PHP timezone, just do exactly what the doc says in PHP documentation.
