How to add Fiberhome MIB to LibreNMS? Thanks.
Fiberhome MIB file: https://www.dropbox.com/s/toqlp7pv6cr4lhi/GPON%26IPRAN%20MIB.rar?dl=0
Adding MIB just by itself dose nothing. What are trying to monitor on the Fiberhome?
You will need to do the following in order to get support for that device.
submit request support in git hub, PLEASE PROVIDE ALL INFO REQUESTED IN THE TEMPLATE DO NOT DELETE THE INFO in the template.
Link here -> https://github.com/librenms/librenms/issues
Requesting info see here - All info that is required for adding GPON and MPLS support you will need to provide with the OID’s are. https://docs.librenms.org/#Support/FAQ/#faq20
or you can code it yourself and make a pull request.
https://docs.librenms.org/#Developing/Support-New-OS/
Thank you very much!
