How to change the default warning value for auto discovery
Hi everyone,
I am new for using LibreNMS system. I am facing a problem that the default warning level “75” of the “Processors” or “Memory” cannot change. If I change the warning value and then “Rediscover device”, it will resume the default value to 75. How to change it? I try to research in internet but seems not one can answer this.
Thank you.
librenms@XXXXXX:~$ ./validate.php
LibreNMS 24.10.1-57-gd8ac25e2d (2024-11-20T22:51:35+08:00)
DB Schema 2024_10_13_162920_add_custom_map_nodeimage_column (307)
PHP 8.1.2-1ubuntu2.22
Python 3.10.12
SNMP 5.9.1
[OK] Composer Version: 2.9.2
[WARN] PHP version 8.2 is the minimum supported version as of October, 2024. We recommend you update PHP to a supported version (8.3 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
[WARN] Your install is over 24 hours out of date, last update: Wed, 20 Nov 2024 14:51:35 +0000
You can switch back to master with git checkout master
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
Default value cannot be changed as far as I know.
But this issue was fixed a long time ago. Now the alert values are kept if manually changed. You just need to upgrade your LibreNMS instance.
