Hello
I go to “Maps->Custom Map Editor” and create a new map.
I want to put this new map in a “Menu Group”.
How can I create “Menu Groups” for my custom maps?
Thank you.
BR
Bruno Sousa
Hello
Thank you.
BR
Bruno Sousa
When editing your Map - click Edit Map Settings top left and enter the Menu name you want under Menu Group. Just type in the heading you want and Save.
Once you’ve done the first one - it will then appear there as a drop-down for subsequent maps.
If you have no maps using the Group, it will go away on its own.
Good morning,
I was able to do it.
Thank you for the help!
BR
Bruno Sousa
