Is it possible to display on the dashboard the overall traffic of a single device as a widget
Yes. Select the “Graph” Type widget and choose “device_bits” as the graph type.
Also you may want to set “no” to legends if you have more than 5 network interfaces on the device.
thank you very much @temporal-lin
