I am trying to figure out how to drop some data out of librenms. I am using the smart plugin to get data from a FreeBSD NAS (FreeNAS), but the graphs in librenms display some garbage data:
The output of the smart plugin looks good:
[email protected]:/mnt/sirius/homes/snmp # ./smart
ada0,0,null,null,null,0,0,0,null,29,36,null,0,null,0,null,0,21,0,0,0,6,15,0,0
ada1,0,null,null,null,0,0,0,null,29,36,null,0,null,0,null,0,21,0,0,0,6,15,0,0
da0,0,0,null,null,null,null,null,null,null,38,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da1,0,0,null,null,null,null,null,null,null,38,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da2,0,0,null,null,null,null,null,null,null,38,0,0,0,1,null,null,21,0,0,0,5,16,0,0
da3,0,0,null,null,null,null,null,null,null,37,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da4,0,0,null,null,null,null,null,null,null,40,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da5,0,0,null,null,null,null,null,null,null,37,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da6,0,0,null,null,null,null,null,null,null,35,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da7,0,0,null,null,null,null,null,null,null,39,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da8,0,0,null,null,null,null,null,null,null,40,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da9,0,0,null,null,null,null,null,null,null,39,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da10,0,0,null,null,null,null,null,null,null,38,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da11,0,0,null,null,null,null,null,null,null,35,0,0,0,0,null,null,21,0,0,0,5,16,0,0
da12,0,0,null,null,null,null,null,null,null,38,0,0,0,0,null,null,0,0,0,0,0,0,0,0
da13,0,0,null,null,null,null,null,null,null,39,0,0,0,0,null,null,0,0,0,0,0,0,0,0
da14,0,0,null,null,null,null,null,null,null,39,0,0,0,0,null,null,0,0,0,0,0,0,0,0
da15,0,0,null,null,null,null,null,null,null,39,0,0,0,0,null,null,0,0,0,0,0,0,0,0
da16,0,0,null,null,null,null,null,null,null,38,0,0,0,0,null,null,0,0,0,0,0,0,0,0
da17,0,0,null,null,null,null,null,null,null,35,0,0,0,0,null,null,0,0,0,0,0,0,0,0
but in the graphs, I see some perl garbage metrics:
All Drives | drives: ada0, ada1, da0, da1, da10, da11, da12, da13, da14, da15, da16, da17, da2, da3, da4, da5, da6, da7, da8, da9, env__, env__perl__No_such_file_or_directory, env__smartctl, env__smartctl__No_such_file_or_directory
Since the output of the command looks ok, I think the metrics are reported correctly (there may have been an issue in the past) but how can i get rid of the “env_perl_no_such_file_or_directory”, etc lines so only the drives show up?
LibreNMS | 1.39-4-gd257fa0
DB Schema | 249
PHP | 7.2.4-1+ubuntu16.04.1+deb.sury.org+1
MySQL | 10.1.31-MariaDB-1~xenial
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 1.6.4
I tried dumping the mysql database and grepping for " env__smartctl", but no matches came up, leading me to believe this might be a rendering issue and not a database/data issue?
[email protected]:~# grep env__smartctl /tmp/sql.sql
Thanks!
