Hi everyone,
I’m a beginner in LIBRENMS API and I use it to get traffic activities on some ports.
But I don’t know how can I do that.
Can someone give me a little help on it ?
Hi everyone,
https://docs.librenms.org/API/Ports/#get_port_info ifSpeed is the field you are looking for (that is reported by the device as the link speed)
Thanks @murrant for your answer
Do The ifSpeed value change with the traffic? Because for me the value never change , may be it’s normal and I want to know a peak of traffic by day.
This has just been discussed on our discord server, please join that and search for get_port_info and read through from the last mention of it
I asked that question because I need to get all data related to one port during a period precise to build a statistic with other informations. And Idon’t know where I have to go for getting those data.
If you want precise info, use the billing module. https://docs.librenms.org/Extensions/Billing-Module/
