Dear LibreNMS community,
currently I’m facing we an issue regarding smokeping intergration.
My ping prob is already set to 30 sec. Is it possible to use this value also for the smokeping prob?
Thanks in advance.
BR
Patrick
Thanks in advance.
BR
Patrick
Im not totally sure to what is your question… Smokeping its another software with another configuration.
You can set your smokeping to whatever time you want. I have mine to run 5 pings every 10 seconds.
Thx Doc,
but my question is were to set the value to reduce smokeping prob to about 30sec?
In the default Setup smokeping prob runs every 300sec an make 20 requests.
Btw: I‘ve had setup smokeping with LibreNMS intergration.
Here https://oss.oetiker.ch/smokeping/probe/FPing.en.html
In the smokeping probe FPing section, set your interval and your ping quantity.
LibreNMS integration does nothing in the smokeping config.
EDIT: After changing the smokeping configuration, remember to reload it to take the new config.
