How to monitor a specific port?
Hello ,
I have public IP addresses and also private what if I want to monitor a specific ports on a device using alert rules ?
Best Regards
Just reference the port by name in the alert rule, ifName or ifAlias.
Can I do it for a network range ? and how I can do it ?
Thanks in advance
By IP that would be a lot harder and I’m not even sure possible without a very complex SQL query (so I guess the answer is yes if you want to put the work in to figure it out). You can easily do it against device type or a regex on hostnames or similar things like that.
