we have ruckuss controller and we try to add on libre but the graph is limited and i try to googling about how to add the graph about but nothing.
there are the thing i want to graph :
CPU Usage
Traffic by SSID
Interface Traffic
AP in Total
Connected Clients
i can see the graph Wireless_clients but the graph is error. There is any doc i can read to try ?
sorry i not read the code carefully, so i just need to change the ‘os’ variable which is same from database, am i correct? sorry if you confused cause i am not a good code reader
if i want graph another device i just create the new php code with that example?
You need to create the filenames using the OS name yes but within the code then you need to use the correct OIDs to get the data. If you get stuck either create a pull request on github with what you have so someone can take a look or create an issue and provide the information we ask for so someone else can add the support.
