I monitor a lot of kvm (also some ovz/lxc containers), but librenms pulls a ram usage that is not correct.
For example: KVM with 24GB RAM, where 4.5GB RAM are used, but librenms shows 22GB usage (both virtual and physical), because the buff/cache is 18GB, which it reads from the host node.
Is there any option to detect kvm/vmware etc.pp. and ignore the buff/cache value, and just work with the ‘used’ value?
