My database crashed so I created a fresh db for LibreNMS.
Now I goto hostname/install it shows
403 This should only be called during install
I’ve run build-base.php and validate.php passes.
| LibreNMS | 1.68-10-g5b892dc4f |
| DB Schema | 2020_09_22_172321_add_alert_log_index (174) |
| PHP | 7.3.19-1~deb10u1 |
| Python | 3.7.3 |
| MySQL | 10.3.23-MariaDB-0+deb10u1 |
| RRDTool | 1.7.1 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.13
[WARN] You have no devices.
Consider adding a device such as localhost: /addhost
Now I can open the login page but I don’t have an account to login.
Question is how do I go though the installation steps again or something else to bring it back with a fresh install?
thank you
