Greetings,
I created a alert rule to monitor when memory usage is greater than 95%, and ignore one specific ID
Later I want to ignore more specific ID, and I stuck.
two or more ‘not equal’ are meaningless.
Any advice, please?
Greetings,
Any advice, please?
It looks like you added mempool_id as a group, so the current logic is:
mempool_perc >= 95 AND (mempool_id != 22)
What if you made the mempool_id group an AND comparison:
mempool_perc >= 95 AND (mempool_id != 22 AND mempool_id != 32)
Probably don’t need the group in this case, but I’m doing logic at 08:00 so who knows.
Not bad for 8:00 AM @Heath_Barnhart
You can test this @Joe_Hsu, looks like it will solve your AND/OR/NOT logik issue
