How to set individual sensor max/min values
new to Librenms, I’ve set up a system with about 20 routers of different makes. I regularly get email alerts stating that some router has gone above or below a threshold. I’m using the included out-of-the-box templates. The version is dda62d8.
Where can I set the alert thresholds for each individual router?
Macsmith
Edit the device -> sensors
thanks for the reply. Excuse again my ignorance, where on the web gui (or do you mean from ssh) can they be edited. Screenshot below of the device.
Macsmith
Sorry it’s under health.
thanks again, screenshot of Health below. I can see that the High and Low fields are editable but my interpretation of them was that these were the measured highs and lows, rather than set thresholds.
Is this the case?
Macsmith
They are the thresholds.
ok,
many thanks
Macsmith
Hey all,
Sorry for the thread necromancy, but, I’m having an issue where I change the threshold values on the fan speed for a QNAP NAS. This works until the next day, and then the values get reset to default. I’m assuming this has something to do with the discovery process, but no clue how to remedy it.
Any help is greatly appreciated!
Cheers!
How do I change those default thresholds globally and not just for one device in Librenms?
Thank you in advance.
You can’t at present
