How to set librenms nagios plugins check_flexlm
Who has set it up, I can’t set it correctly.
Seems to be a couple of versions of that script floating about, however the one I checked (https://github.com/wwest4/monitoring-plugins/blob/master/plugins-scripts/check_flexlm.pl) doesn’t look like it supports -H for hostname and relies on a config file meaning it might not work properly.
How do you run it in the CLI for it to work for you?
