Our main LibreNMS server runs the system’s webUI and it is poller group 0. It polls about 300 devices. Three other pollers exist and they are poller groups 1, 2, 3.
We have several admin-level staff. Going forward we’d like to prevent them from adding new devices to poller group 0. The admins must still be able to add new devices to the other poller groups. Is it possible? If so, how can we configure our overall system to do that?
So far, I looked through LibreNMS’ online documentation, looked at the main server’s config.php, looked at the .env file, and reviewed the main server’s full config list via “lnms config:get --dump”. Maybe the answer was there and I just didn’t recognize it.
Thanks for any ideas you can offer.
| LibreNMS | 24.1.0-56-gcf99657c5 (2024-02-02T09:49:09-06:00) |
| DB Schema | 2024_01_09_211518_custom_map_node_maplink (288) |
| PHP | 8.1.2-1ubuntu2.14 |
| Python | 3.10.12 |
| Database | MariaDB 10.3.38-MariaDB-0ubuntu0.20.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.6.6
- The output of
./validate.php
