Simple question here : is there a way to disable ARP for maps ?
In the documentation, there is the command lnms config:set 'network_map_items' "('mac','xdp') but I have constantly “invalid format” when I use it…
For example :
librenms@ubuntu:~$ lnms config:set 'network_map_items' "('xdp')"
Invalid format
Regards
