Howto get poe data for hpe5130 switch in librenms
Hardware: 5130 24G PoE+ 4SFP+ EI Switch
OS Version: 7.1.070
OS Features: 3507P18
Poe is enabled
lnms config:get poller_modules | grep poe
“poe”: true
If I run “lnms device:poll -x” it is only using the comware mib, which is ok. How can I change the config so that the poller/discovery is using the comware MIB + POWER-ETHERNET-MIB?
Discovery and poller scripts don’t give errors nor warnings. Only the comware mib is used which is ok.
gr.
librenms:/opt/librenms$ ./validate.php
LibreNMS  | 25.4.0 (2025-04-15T16:18:54+02:00)
DB Schema | 2025_03_22_134124_fix_ipv6_addresses_id_type (331)
PHP       | 8.3.19
Python    | 3.12.10
Database  | MariaDB 10.11.8-MariaDB-ubu2204
RRDTool   | 1.9.0
SNMP      | 5.9.4
[OK]    Installed from package; no Composer required
[OK]    No python wrapper pollers found
[OK]    Redis is functional
[OK]    rrd_dir is writable
[WARN]  Non-git install, updates are manual or from package
