HP 1810-24G OIDs
hi all, i would add cpu and ram of hp1810-24g switch, but all oids what i have found dont work. how can i found correct oids for ram and cpu to add it in librenms, well standard don´t shows cpu and memory :frowning:
if i do list all to a txt file i dont knwo what is memory and what cpu
snmpwalk -v 2c -c public myipofdevice
any ideas?
regards
Find the MIBs for your device and add them to your snmpwalk with -M and -m, then walk the device again. It might be easier to figure out if the data you want is available.
hi thats i have done, but cpu, memory and other its not listed, look list. regards
https://file.io/1iPsaabHgOyB
