Thanks the doc, but I have tried everything, inculding this, and still no change on web UI. I don’t understand the structure of php files and the data managing.
So far, so good.
And I can tell you, this is a very, very big luck I reached this far! But fans, hdd states (maybe temparetures) etc. are still missing. But I’m on it, IF i’ll be that lucky in the future too.
What do you mean?
I just activated SNMPv2c or v3 in ILO config (example: https://www.youtube.com/watch?v=x8lP3tjcNqk), then just added the ILO IP address to LibreNMS.
The code in LibreNMS is done. You can grab it from Git now (https://github.com/librenms/librenms) or you will find it in the next release.
FYI: Soon I’ll try to add additional ILO features into LibreNMS (mempools etc).
I need a little help.
I try to add Storage graph to the system. I’m done with the discovery part, but the poller file cannot run.
Are you still use to receive storage information the includes/polling/storage/XY.inc.php files?
I made the hpe-ilo.inc.php, and it’s contain only an echo line, and I cannot see it, when I running poller.php.
