Hp msa p2000
Hey.
If you can add a device HP MSA P2000, 2042, 2052
DiEg,
you should make a git hub issue requesting new devices be added and or requesting more info for sensors and such you will need to provide the SNMP oids. Please provide all of the info asked for.
Also, DO NOT DELETE THE TXT in the git hub issue template. :slight_smile:
snmpbulkwalk -OUneb -v2c -c COMMUNITY HOSTNAME .  | ./pbin.sh
GitHub Issues LibreNMS
issued an application for GitHub
Thank you -
Looks like there is already support for HP MSA P2000. What exactly are you looking to monitor?
I would like to see graphics: virtual disks and iSCSI traffic
I would also find this extremely helpful in my setup.
What would I need to provide to potentially allow monitoring of the health of the disks in the cluster and then the virtual disks themselves.
Thank you
It is necessary to reopen it, because mine was closed due to lack of data
looks like you only provided some of the info, you need to provide everything that is asked for. Then they will re-open it for you.
Hi
Re-opened!!!
I found this , maybe is something that could be developed
Regards
Dave
