HP MSM missing clients af update
Output ./validate.php
$ ./validate.php
LibreNMS 1.52-2-g902c056f6
DB Schema 2019_02_10_220000_add_dates_to_fdb (132)
PHP 7.3.5-1+ubuntu18.04.1+deb.sury.org+1
MySQL 10.1.38-MariaDB-0ubuntu0.18.04.2
RRDTool 1.7.0
SNMP NET-SNMP 5.7.3
[OK] Composer Version: 1.8.5
./discovery.php https://pastebin.com/aL004R2N
./poller.php https://pastebin.com/K06nMbnz
After the daily update the 14/15 th of May my graphes with clients on my HP MSM are 0 have the been any update to the graphes?
Hasn’t been any updates to HP wireless
after the update the graphe are down to 0
Your controller is reporting zero. Looks like issue with SNMP on that device.
  1. OS initialized: LibreNMS\OS\Hpmsm
  • SQL[SELECT * FROM wireless_sensors WHERE device_id = ? [418] 0.43ms]
  • SNMP[’/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQnt’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/hpmsm’ ‘-t’ ‘20’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.8744.5.25.1.7.2.0’]
  • ..4.1.87.7.2.0 = 0
  • clients:
  • array (
  1. 353 => 0,
  2. )
  • Clients: Total: 0
Hi Kevin, thanks for your reply :slight_smile: it looks like after a reboot of the Wireless controlle it was all working again :slight_smile:
