i have upgraded php 7.2 but still error 500 from the browser page
librenms@librenms:/opt/librenms$ sudo a2enmod php7.2
Considering dependency mpm_prefork for php7.2:
Considering conflict mpm_event for mpm_prefork:
Considering conflict mpm_worker for mpm_prefork:
Module mpm_prefork already enabled
Considering conflict php5 for php7.2:
Module php7.2 already enabled
librenms@librenms:/opt/librenms$ ./scripts/composer_wrapper.php install --no-dev
Nothing to install or update
Illuminate\Foundation\ComposerScripts::postAutoloadDump
@php artisan package:discover --ansi
Discovered Package: fideloper/proxy
Discovered Package: laravel/laravel
Discovered Package: laravel/nexmo-notification-channel
Discovered Package: laravel/slack-notification-channel
Discovered Package: laravel/tinker
Discovered Package: nesbot/carbon
Discovered Package: oriceon/toastr-5-laravel
Package manifest generated successfully.
LibreNMS\ComposerHelper::postInstall
Illuminate\Foundation\ComposerScripts::postInstall
librenms@librenms:/opt/librenms$ ./validate.php
| LibreNMS | 1.50-51-g39ff4c7 |
| DB Schema | 2019_02_10_220000_add_dates_to_fdb (132) |
| PHP | 7.2.17-1+ubuntu16.04.1+deb.sury.org+3 |
| MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1 |
| RRDTool | 1.5.5 |
| SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.8.5
[WARN] Your install is over 24 hours out of date, last update: Sat, 20 Apr 2019 17:32:17 +0000
