Hi guys, i am VERY desperate installing LibreNMS:
I did everything according this official guide:
https://docs.librenms.org/Installation/Installation-CentOS-7-Apache/
But appear the typical 500 http error:
Watching the httpd logs:
Tue Mar 31 13:25:11.598924 2020] [php7:warn] [pid 7578:tid 140160956102400] [client 10.102.49.74:52182] PHP Warning: require(/opt/librenms/html/…/bootstrap/autoload.php): failed to open stream: Permission denied in /opt/librenms/html/index.php on line 22
[Tue Mar 31 13:25:11.598971 2020] [php7:error] [pid 7578:tid 140160956102400] [client 10.102.49.74:52182] PHP Fatal error: require(): Failed opening required ‘/opt/librenms/html/…/bootstrap/autoload.php’ (include_path=’.:/usr/share/pear:/usr/share/php’) in /opt/librenms/html/index.php on line 22
[Tue Mar 31 13:25:12.782193 2020] [php7:warn] [pid 7577:tid 140160956102400] [client 10.102.49.74:52183] PHP Warning: require(/opt/librenms/html/…/bootstrap/autoload.php): failed to open stream: Permission denied in /opt/librenms/html/index.php on line 22
[Tue Mar 31 13:25:12.782230 2020] [php7:error] [pid 7577:tid 140160956102400] [client 10.102.49.74:52183] PHP Fatal error: require(): Failed opening required ‘/opt/librenms/html/…/bootstrap/autoload.php’ (include_path=’.:/usr/share/pear:/usr/share/php’) in /opt/librenms/html/index.php on line 22
[Tue Mar 31 13:26:37.702320 2020] [php7:warn] [pid 7576:tid 140160947709696] [client 10.102.49.74:52188] PHP Warning: require(/opt/librenms/html/…/bootstrap/autoload.php): failed to open stream: Permission denied in /opt/librenms/html/index.php on line 22
[Tue Mar 31 13:26:37.702382 2020] [php7:error] [pid 7576:tid 140160947709696] [client 10.102.49.74:52188] PHP Fatal error: require(): Failed opening required ‘/opt/librenms/html/…/bootstrap/autoload.php’ (include_path=’.:/usr/share/pear:/usr/share/php’) in /opt/librenms/html/index.php on line 22
i tried to fixed with chmod 644 /opt/librenms/html/…/bootstrap/autoload.php
chmod 644 -R /opt/librenms/html/…/bootstrap/autoload.php
More info:
./validate.php
Component | Version |
LibreNMS | 1.61-86-gf7f6c63 |
DB Schema | 2020_03_24_0844_add_primary_key_to_device_graphs (160) |
PHP | 7.4.4 |
MySQL | 10.4.12-MariaDB |
RRDTool | 1.4.8 |
SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.1
Could someone help me please??
