hello everyone,
i get the following error when i try to reach libre from my web browser. validation also returns with some errors. i am using FreeBSD 11.1.
i appreciate any help. thank you in advance.
Cannot redeclare str_contains() (previously declared in /usr/local/www/librenms/vendor/laravel/framework/src/Illuminate/Support/helpers.php:773) [2] => /usr/local/www/librenms/includes/common.php [3] => 1377 )
PHP Fatal error: Cannot instantiate abstract class LibreNMS\Validations\BaseValidation in /usr/local/www/librenms/LibreNMS/Validator.php on line 49
Component |
Version |
LibreNMS |
1.39-34-g303336bce |
DB Schema |
PHP |
5.6.35 |
MySQL |
RRDTool |
1.7.0 |
SNMP |
NET-SNMP 5.7.3 |
I wonder if you have some mix up with files as str_contains
has a safety checkin includes/common.php
but on different lines than your output is reported.
Does validate show anything else past the ===== lines
hello!!
no, validation shows nothing under the ===== lines
i ran php composer_wrapper.php install --no-dev command cause i am having some issues with my libre installation. ( i was getting errors after daily update jobs- this command was suggested as a solution.
now i cant even get to frontpage. i dont have any php programming experience.
What does the front page say?
it says http error 500.
with debug mode is on , it says Array ( [0] => 1 [1] => Cannot redeclare str_contains() (previously declared in /usr/local/www/librenms/vendor/laravel/framework/src/Illuminate/Support/helpers.php:773) [2] => /usr/local/www/librenms/includes/common.php [3] => 1377 )
I think your code is out of date, run git status
hello
it outputs the following information . too many information on the screen. not sure whether to post all of them.
On branch master
Your branch is up to date with ‘origin/master’.
Changes not staged for commit:
(use “git add/rm …” to update what will be committed)
(use “git checkout – …” to discard changes in working directory)
modified: LibreNMS/Alert/Transport/Api.php
modified: LibreNMS/Alert/Transport/Boxcar.php
modified: LibreNMS/Alert/Transport/Canopsis.php
modified: LibreNMS/Alert/Transport/Ciscospark.php
modified: LibreNMS/Alert/Transport/Clickatell.php
modified: LibreNMS/Alert/Transport/Dummy.php
modified: LibreNMS/Alert/Transport/Elasticsearch.php
modified: LibreNMS/Alert/Transport/Hipchat.php
modified: LibreNMS/Alert/Transport/Irc.php
modified: LibreNMS/Alert/Transport/Jira.php
modified: LibreNMS/Alert/Transport/Mail.php
modified: LibreNMS/Alert/Transport/Msteams.php
modified: LibreNMS/Alert/Transport/Nagios.php
modified: LibreNMS/Alert/Transport/Osticket.php
modified: LibreNMS/Alert/Transport/Pagerduty.php
modified: LibreNMS/Alert/Transport/Playsms.php
modified: LibreNMS/Alert/Transport/Pushbullet.php
Yeah, you are going to need to fix that.
./scripts/github-remove -d
will revert all those, then, you can run ./daily.sh again.
sir ,
everything went back to normal after that command!!
thank you so much.
what was the exact problem of my libre distro ?
Some sort of git update failure, perhaps you had some locally modifed files?
Should be good to go now.
