I use LibreNMS for monitoring Huawei OLT’s. Unfortunately Libre doesn’t draw any graphs for GPON ports like gpon 0/0/0. It only works with Uplink ports like et0/9/0. Any solosion how to fix it?
Libre version: 21.11.0-12-gf8764ddcb - Wed Nov 17 2021 04:40:29 GMT+0100
OLT models:
MA5800-X7 with OS MA5800V100R019C11B066
MA5603T with OS MA5603V800R015C00B058
MA5608T with OS MA5603V800R015C00B058
Validate PHP:
librenms@librenms-alias:~$ ./validate.php
Component | Version |
LibreNMS | 21.11.0-12-gf8764ddcb |
DB Schema | 2021_11_12_123037_change_cpwVcID_to_unsignedInteger (225) |
PHP | 7.4.3 |
Python | 3.8.10 |
MySQL | 10.3.31-MariaDB-0ubuntu0.20.04.1 |
RRDTool | 1.7.2 |
SNMP | NET-SNMP 5.8 |
[OK] Composer Version: 2.1.12
[FAIL] Database: incorrect column (notifications/datetime)
[FAIL] Database: incorrect column (users/created_at)
[FAIL] We have detected that your database schema may be wrong
Run the following SQL statements to fix it
SQL Statements:
SET TIME_ZONE=’+00:00’;
ALTER TABLE notifications
CHANGE datetime
datetime
timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:00’ ;
ALTER TABLE users
CHANGE created_at
created_at
timestamp NOT NULL DEFAULT ‘1970-01-02 00:00:01’ ;
[FAIL] Python3 module issue found: 'Required packages: [‘PyMySQL!=1.0.0’, ‘python-dotenv’, ‘redis>=3.0’, ‘setuptools’, ‘psutil>=5.6.0’, ‘command_runner>=1.3.0’]
Package not found: The ‘command_runner>=1.3.0’ distribution was not found and is required by the application
