Huawei switch LLDP
Have anyone have success with showing LLDP info from a Huawei switch 5700 or 1720 in webui.
I do not get a neighbors tab in webui for my Huawei devices.
Can anyone help me troubleshoot this issue?
After long last I have found the issue. The Huawei switch configuration is at fault. Huawei switch need custom SNMP configuration for getting LLDP information via SNMP.
Here is a sample reference of commands -
#enable snmp
snmp-agent
#enable snmp version 2c
snmp-agent sys-info version v2c
#we need to create a view which will include β€˜iso’ mib objects
snmp-agent mib-view included iso-view iso
#Enable snmp read which includes our mib-view created above
snmp-agent community read test123 mib-view iso-view
For further reference -
http://support.huawei.com/hedex/pages/SE0000538123DEA01273/03/SE0000538123DEA01273/03/resources/s/dc_s_faq_000190.html
https://support.huawei.com/enterprise/en/doc/EDOC1000091885/c0dbe894/why-the-lldp-neighbor-information-cannot-be-obtained-through-snmp-or-the-operations-performed-on-lldp-mib-objects-do-not-take-effect
This can be closed now. Hope it helps somebody else.
