Below is sensors polling log for cisco switch . Poll your device from webui and capture the sensors part
Load poller module sensors
SQL[SELECT sensor_class FROM sensors WHERE device_id = ? GROUP BY sensor_class [1619] 1.04ms]
SQL[SELECT * FROM sensors WHERE sensor_class = ? AND device_id = ? [“count”,1619] 1.21ms]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQntea’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/cisco’ ‘-t’ ‘5’ ‘-r’ ‘10’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.9.9.402.1.4.1.0’]
...4*.0 = 19
Checking (snmp) count PoE Devices Connected…
Reporting disabled by user setting
19
SQL[SELECT * FROM sensors WHERE sensor_class = ? AND device_id = ? [“power”,1619] 1.97ms]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQntea’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/cisco’ ‘-t’ ‘5’ ‘-r’ ‘10’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.2.1.105.1.3.1.1.2.1’]
...*.1 = 780
Checking (snmp) power PoE Budget Total - ID 1…
780 W
SQL[SELECT * FROM sensors WHERE sensor_class = ? AND device_id = ? [“state”,1619] 1.74ms]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQntea’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/cisco’ ‘-t’ ‘5’ ‘-r’ ‘10’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.9.9.13.1.3.1.6.1010’ ‘.1.3.6.1.4.1.9.9.13.1.3.1.6.1011’ ‘.1.3.6.1.4.1.9.9.13.1.3.1.6.1012’ ‘.1.3.6.1.4.1.9.9.13.1.4.1.3.1015’ ‘.1.3.6.1.4.1.9.9.13.1.4.1.3.1016’ ‘.1.3.6.1.4.1.9.9.13.1.4.1.3.1017’ ‘.1.3.6.1.4.1.9.9.13.1.5.1.3.1013’ ‘.1.3.6.1.4.1.9.9.13.1.5.1.3.1014’ ‘.1.3.6.1.4.1.9.9.117.1.1.2.1.2.1013’ ‘.1.3.6.1.4.1.9.9.117.1.1.2.1.2.1014’]
....6.1010 = 1
....6.1011 = 1
....6.1012 = 1
....3.1015 = 1
....3.1016 = 1
....3.1017 = 1
....3.1013 = 1
....3.1014 = 1
....1.2.1013 = 2
....1.2.1014 = 2
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQntea’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/cisco’ ‘-t’ ‘5’ ‘-r’ ‘10’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.9.9.176.1.1.2.0’ ‘.1.3.6.1.4.1.9.9.176.1.1.4.0’ ‘.1.3.6.1.4.1.9.9.176.1.2.14.0’]
....0 = 14
....0 = 2
...*.0 = 8
Checking (snmp) state Switch 1 - Temp Sensor 0, GREEN…
Checking (snmp) state Switch 1 - Temp Sensor 1, GREEN…
Checking (snmp) state Switch 1 - Temp Sensor 2, GREEN…
Checking (snmp) state Switch 1 - FAN 1, Normal…
Checking (snmp) state Switch 1 - FAN 2, Normal…
Checking (snmp) state Switch 1 - FAN 3, Normal…
Checking (snmp) state Switch 1 - Power Supply A, Normal…
Checking (snmp) state Switch 1 - Power Supply B, Normal…
Checking (snmp) state Switch 1 - Power Supply A…
Checking (snmp) state Switch 1 - Power Supply B…
Checking (snmp) state VSS Device State…
Checking (snmp) state VSS Peer State…
Checking (snmp) state VSS Mode…
1 #
1 #
1 #
1 #
1 #
1 #
1 #
1 #
2 #
2 #
14 #
2 #
8 #
SQL[SELECT * FROM sensors WHERE sensor_class = ? AND device_id = ? [“temperature”,1619] 2.23ms]
SNMP[‘/usr/bin/snmpget’ ‘-v2c’ ‘-c’ ‘COMMUNITY’ ‘-OUQntea’ ‘-M’ ‘/opt/librenms/mibs:/opt/librenms/mibs/cisco’ ‘-t’ ‘5’ ‘-r’ ‘10’ ‘udp:HOSTNAME:161’ ‘.1.3.6.1.4.1.9.9.91.1.1.1.1.4.1010’ ‘.1.3.6.1.4.1.9.9.91.1.1.1.1.4.1011’ ‘.1.3.6.1.4.1.9.9.91.1.1.1.1.4.1012’ ‘.1.3.6.1.4.1.9.9.13.1.3.1.3.1010’ ‘.1.3.6.1.4.1.9.9.13.1.3.1.3.1011’ ‘.1.3.6.1.4.1.9.9.13.1.3.1.3.1012’]
....1.4.1010 = 30
....1.4.1011 = 36
....1.4.1012 = 41
....3.1010 = 30
....3.1011 = 36
....3.1012 = 41
Checking (snmp) temperature Switch 1 - Temp 0…
Checking (snmp) temperature Switch 1 - Temp 1…
Checking (snmp) temperature Switch 1 - Temp 2…
Checking (snmp) temperature Switch 1 - Temp Sensor 0, GREEN…
Checking (snmp) temperature Switch 1 - Temp Sensor 1, GREEN…
Checking (snmp) temperature Switch 1 - Temp Sensor 2, GREEN…
30 C
36 C
41 C
30 C
36 C
41 C
Runtime for poller module ‘sensors’: 0.9475 seconds with 3368 bytes
SNMP: [5/0.89s] MySQL: [5/0.08s]
Unload poller module sensors
