librenms@librenms:~$ ./daily.sh
Fetching new release information OK
Between releases, waiting for newer release
Updating Composer packages OK
Updated from unset to OK
Updating SQL-Schema OK
Updating submodules OK
Cleaning up DB OK
Fetching notifications OK
Caching PeeringDB data OK
Caching Mac OUI data OK
| LibreNMS | 23.2.0-45-g468305651 (2023-03-30T06:41:01-04:00) |
| DB Schema | 2023_03_14_130653_migrate_empty_user_funcs_to_null (249) |
| PHP | 8.1.7-1ubuntu3.3 |
| Python | 3.10.7 |
| Database | MariaDB 10.6.12-MariaDB-0ubuntu0.22.10.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.3 |
[OK] Composer Version: 2.5.5
[OK] MySQl and PHP time match
[FAIL] No active polling method detected
I am on the monthly update. Have try changing permissions of /etc/cron.d/librenms and a number of other hacks listed here but nothing seems to help. Any ideas ??
i can manually run ./poller-wrapper.py but it has stopped running automatically
asg@librenms:~$ systemctl status cron.service
â cron.service - Regular background program processing daemon
Loaded: loaded (/lib/systemd/system/cron.service; enabled; preset: enabled)
Active: active (running) since Wed 2023-04-05 14:35:58 EDT; 36s ago
Docs: man:cron(8)
Main PID: 2046784 (cron)
Tasks: 1 (limit: 14198)
Memory: 332.0K
CPU: 1.580s
CGroup: /system.slice/cron.service
ââ2046784 /usr/sbin/cron -f -P
Apr 05 14:35:58 librenms cron[2046784]: (CRON) INFO (Skipping @reboot jobs – not system startup)
Apr 05 14:36:01 librenms CRON[2046787]: pam_unix(cron:session): session opened for user librenms(uid=998) by (uid=0)
Apr 05 14:36:01 librenms CRON[2046786]: pam_unix(cron:session): session opened for user librenms(uid=998) by (uid=0)
Apr 05 14:36:01 librenms CRON[2046788]: (librenms) CMD ( /opt/librenms/alerts.php >> /dev/null 2>&1)
Apr 05 14:36:01 librenms CRON[2046789]: (librenms) CMD ( /opt/librenms/ping.php >> /dev/null 2>&1)
Apr 05 14:36:01 librenms CRON[2046785]: pam_unix(cron:session): session opened for user librenms(uid=998) by (uid=0)
Apr 05 14:36:01 librenms CRON[2046790]: (librenms) CMD ( cd /opt/librenms/ && php artisan schedule:run >> /dev/null 2>&1)
Apr 05 14:36:02 librenms CRON[2046787]: pam_unix(cron:session): session closed for user librenms
Apr 05 14:36:02 librenms CRON[2046785]: pam_unix(cron:session): session closed for user librenms
Apr 05 14:36:02 librenms CRON[2046786]: pam_unix(cron:session): session closed for user librenms
asg@librenms:~$
