Dears
I can´t clic “edit” button of widgets
Thanks!
Dears
Thanks!
Are you talking about the Apple IOS app?
Ok, you posted this in the “MyLibrenms Help” you should re-post this in the help group.
If the button is disabled sounds like you don’t have right to change the widget. are logged in as admin? Do you have write access to that dashboard?
