I cannot get port statistics for any device
This morning I suddenly got the following error when I didn’t make any changes. Please help me to fix that.
Error page:
librenms.log:
Trying to access array offset on value of type null {“view”:{“view”:“/opt/librenms/resources/views/device/index.blade.php”,“data”:},“userId”:43,“exception”:“[object] (Spatie\LaravelIgnition\Exceptions\ViewException(code: 0): Trying to access array offset on value of type null at /opt/librenms/app/Http/Controllers/Device/Tabs/NetflowController.php:39)
[previous exception] [object] (ErrorException(code: 0): Trying to access array offset on value of type null at /opt/librenms/app/Http/Controllers/Device/Tabs/NetflowController.php:39)”}
validate.php:
$ ./validate.php
LibreNMS 24.6.0-6-g592ea1c26 (2024-06-17T22:09:33+08:00)
DB Schema 2024_04_29_183605_custom_maps_drop_background_suffix_and_background_version (294)
PHP 8.1.11
Python 3.6.9
Database MySQL 5.7.42-0ubuntu0.18.04.1
RRDTool 1.7.0
SNMP 5.7.3
[OK] Composer Version: 2.7.7
Here we cant open the ports page:
Call to a member function displayName() on null {“view”:{“view”:“/opt/librenms/resources/views/components/port-link.blade.php”,“data”:},“userId”:46,“exception”:“[object] (Spatie\LaravelIgnition\Exceptions\ViewException(code: 0): Call to a member function displayName() on null at /opt/librenms/resources/views/components/port-link.blade.php:4)
[previous exception] [object] (Error(code: 0): Call to a member function displayName() on null at /opt/librenms/storage/framework/views/78eb6cfc8bfb5dadb61279e2703027c8.php:13)”}
$ ./validate.php
LibreNMS 24.6.0-1294-gd837444e7 (2024-06-18T07:00:10-03:00)
PHP 8.2.0
Python 3.9.2
Database MariaDB 10.3.25-MariaDB-0+deb10u1
RRDTool 1.7.1
SNMP 5.7.3
update to latest codebase with ./daily.sh . this fixed it for me.
Sorry, It did not work. Is there any other solution?
Same problem here, update with daily.sh doesn’t help.
Hello. Same problem with ports
But link:
  • librenms/device/XX/ports isn’t work
  • librenms/device/XX/ports/basic - work
For different devices errors gone after updating port settings in the preference for the device librenms/device/XX/edit/section=ports by pressing “Save Toggles”
For juniper devices, it doesn’t help
