Neo85
26 April 2022 21:23
#1
I’ve finished installing from the terminal now … if I try to connect to xxx.xxx.xxx.xxx the page doesn’t respond! I still have to take the first steps from Webgui … if I launch from the terminal .validate here’s what …
LibreNMS | 22.4.0-18-g70bae6605
DB Schema | Not Connected (0)
PHP | 7.4.3
Python | 3.8.10
MySQL | Not Connected
RRDTool | 1.7.2
SNMP | 5.8
[OK] Composer Version: 2.3.5
[email protected] :/opt/librenms/logs# tail librenms.log
#24 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(905): Illuminate\Foundation\Application->bootProvider()
#25 [internal function]: Illuminate\Foundation\Application->Illuminate\Foundation\{closure}()
#26 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(906): array_walk()
#27 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/BootProviders.php(17): Illuminate\Foundation\Application->boot()
#28 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Application.php(237): Illuminate\Foundation\Bootstrap\BootProviders->bootstrap()
#29 /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Console/Kernel.php(310): Illuminate\Foundation\Application->bootstrapWith()
#30 /opt/librenms/LibreNMS/Util/Laravel.php(44): Illuminate\Foundation\Console\Kernel->bootstrap()
#31 /opt/librenms/includes/init.php(87): LibreNMS\Util\Laravel::bootCli()
#32 /opt/librenms/alerts.php(34): require('/opt/librenms/i...')
#33 {main}
Greetings
system
Closed
25 July 2022 21:23
#2
