got it, thanks
Hi Kelvin,
Is it also possible to add public internet icmp checks?
How Can I specify hosts checks without having devices defined
Yup with Nagios Plugins - LibreNMS Docs
looks like it hasn’t run yet it should go green, after 5 minutes
By the way, why while configuring it , it asks for device in addition to destination ip?
Does it send icmp from the device? or from the librenms host?
It just sends it from librenms server
Strange,when you add a new service you need to specify the device in addition to destination ip
So specifying a device is just for reference, the checks are still done from the librenms host
Yes that is Correct
strange, fping still not coming green
Run through the doc again make sure you did everything.
Most common mistake is not setting the plugins to excitable and not setting up the cron for check services.
also you can run from cli ./check-services.php -d and that will give you an idea whats going on.
After I run this command ./check-services.php -d
it became green
Hi Kevin,
It works good , thanks ,now Can I trigger the alerts based on the services of nagios plugin?
I don’t see service packet loss
Hi Kelvin,
The nagios fping checks are referred to the same fping adjustment I did on config.php for cron checks?
Or there is any other file where I can adjust intervals of fping checks on the Nagios service
Yes, you can trigger alerts. For service up and down and warning but that’s it.
Hi Kelvin,
that i do not know
