Hi all,
It would be great if we had %ifSpeed_prev to use in alerting rules. That would allow us to find interfaces that speed degraded.
Thanks and regards,
Michał
Hi all,
Thanks and regards,
Michał
Weird I thought we did?
Did you look under?
ports.if
Hi Kevin,
I just checked and I have only %ports.ifSpeed. I am checking it with Form autocompletion. Is it possible that it doesn’t autocomplete but exists anyway?
Thanks and regards,
Michał
Give it a try, I have seen in some cases autocomplete not work the way its supposed too. heh
We don’t have ifSpeed_prev or ifHighSpeed_prev at present
