Working version on ubuntu 16LTS,
i have the following on .env file, but still the same issue.
APP_URL=http://localhost
Then upgraded ubuntu to 18 LTS, resulting more issues.
php module7.4 is enabled and apache restarted.
On browser it says "Composer detected issues in your platform: Your Composer dependencies require a PHP version “>= 7.3.0”.
And i’m not even sure if librenms is collecting data in the background.
Ubuntu 16LTS
$ ./validate.php
LibreNMS | 1.63-57-g0040f38
DB Schema | 2020_04_19_010532_eventlog_sensor_reference_cleanup (164)
PHP | 7.2.29-1+ubuntu16.04.1+deb.sury.org+1
Python | 3.5.2
MySQL | 10.0.38-MariaDB-0ubuntu0.16.04.1
RRDTool | 1.5.5
SNMP | NET-SNMP 5.7.3
[OK] Composer Version: 2.1.5
[WARN] Your install is over 24 hours out of date, last update: Tue, 30 Jun 2020 14:09:39 +0000
You can switch back to master with git checkout master
$ git checkout master
Checking out files: 100% (8233/8233), done.
Switched to branch 'master'
Your branch is up-to-date with 'composer/master'.
$ ./daily.sh
In Request.php line 329:
Argument 1 passed to Symfony\Component\HttpFoundation\Request::create() must be of the type string, null given, called in /opt/librenms/vendor/laravel/framework/src/Illuminate/Foundation/Bootstrap/SetRe
questForConsole.php on line 32
Updating SQL-Schema OK
Cleaning up DB OK
Ubuntu 18 LTS
$ git pull
Updating e9c89b377..bc56f94f8
output manually removed, will provide if required.
$ ./daily.sh
In PackageManifest.php line 122:
Undefined index: name
Cleaning up DB OK
$ ./validate.php
LibreNMS | 21.7.0-80-gbc56f94f8
DB Schema | Not Connected (0)
PHP | 7.4.22
Python | 3.6.9
MySQL | ?
RRDTool | 1.7.0
[OK] Composer Version: 2.1.6
[FAIL] Missing dependencies!
/opt/librenms/scripts/composer_wrapper.php install --no-dev
Dependencies:
doctrine/deprecations
webmozart/assert
voku/portable-ascii
symfony/polyfill-php80
graham-campbell/result-type
symfony/deprecation-contracts
symfony/polyfill-intl-normalizer
symfony/http-client-contracts
psr/event-dispatcher
symfony/polyfill-intl-grapheme
symfony/string
ramsey/collection
brick/math
league/mime-type-detection
league/commonmark
and 13 more...
$ ./scripts/composer_wrapper.php install --no-dev
> LibreNMS\ComposerHelper::preInstall
Verifying lock file contents can be installed on current platform.
Package operations: 28 installs, 62 updates, 11 removals
- Downloading amenadiel/jpgraph (3.6.14)
- Downloading clue/socket-raw (v1.5.0)
- Downloading dapphp/radius (2.5.5)
- Downloading doctrine/deprecations (v0.5.3)
- Downloading doctrine/cache (2.0.3)
- Downloading doctrine/dbal (2.13.2)
- Downloading symfony/polyfill-ctype (v1.23.0)
- Downloading webmozart/assert (1.10.0)
- Downloading dragonmantank/cron-expression (v3.1.0)
- Downloading voku/portable-ascii (1.5.6)
- Downloading symfony/polyfill-php80 (v1.23.0)
- Downloading symfony/polyfill-mbstring (v1.23.0)
- Downloading graham-campbell/result-type (v1.0.1)
- Downloading vlucas/phpdotenv (v5.3.0)
- Downloading symfony/css-selector (v5.3.0)
- Downloading symfony/var-dumper (v5.3.3)
- Downloading symfony/deprecation-contracts (v2.4.0)
- Downloading symfony/routing (v5.3.0)
- Downloading symfony/process (v5.3.2)
- Downloading symfony/polyfill-php72 (v1.23.0)
- Downloading symfony/polyfill-intl-normalizer (v1.23.0)
- Downloading symfony/polyfill-intl-idn (v1.23.0)
- Downloading symfony/mime (v5.3.2)
- Downloading symfony/polyfill-php73 (v1.23.0)
- Downloading symfony/http-foundation (v5.3.3)
- Downloading symfony/http-client-contracts (v2.4.0)
- Downloading symfony/event-dispatcher-contracts (v2.4.0)
- Downloading symfony/event-dispatcher (v5.3.0)
- Downloading psr/log (1.1.4)
- Downloading symfony/error-handler (v5.3.3)
- Downloading symfony/http-kernel (v5.3.3)
- Downloading symfony/finder (v5.3.0)
- Downloading symfony/polyfill-intl-grapheme (v1.23.0)
- Downloading symfony/string (v5.3.3)
- Downloading psr/container (1.1.1)
- Downloading symfony/service-contracts (v2.4.0)
- Downloading symfony/console (v5.3.2)
- Downloading symfony/polyfill-iconv (v1.23.0)
- Downloading egulias/email-validator (2.1.25)
- Downloading swiftmailer/swiftmailer (v6.2.7)
- Downloading ramsey/collection (1.1.3)
- Downloading brick/math (0.9.2)
- Downloading opis/closure (3.6.2)
- Downloading symfony/translation-contracts (v2.4.0)
- Downloading symfony/translation (v5.3.3)
- Downloading nesbot/carbon (2.50.0)
- Downloading monolog/monolog (2.3.0)
- Downloading league/mime-type-detection (1.7.0)
- Downloading league/flysystem (1.1.4)
- Downloading league/commonmark (1.6.5)
- Downloading laravel/framework (v8.49.2)
- Downloading fico7489/laravel-pivot (3.0.7)
- Downloading fideloper/proxy (4.4.1)
- Downloading asm89/stack-cors (v2.0.3)
- Downloading fruitcake/laravel-cors (v2.0.4)
- Downloading jenssegers/model (v1.4.0)
- Downloading genealabs/laravel-caffeine (8.0.0)
- Downloading guzzlehttp/promises (1.4.1)
- Downloading psr/http-factory (1.0.1)
- Downloading guzzlehttp/psr7 (2.0.0)
- Downloading psr/http-client (1.0.1)
- Downloading guzzlehttp/guzzle (7.3.0)
- Downloading influxdb/influxdb-php (1.15.2)
- Downloading justinrainbow/json-schema (5.2.11)
- Downloading nikic/php-parser (v4.11.0)
- Downloading psy/psysh (v0.10.8)
- Downloading laravel/tinker (v2.6.1)
- Downloading laravel/ui (v3.3.0)
- Downloading nunomaduro/laravel-console-summary (v1.7.1)
- Downloading pear/net_dns2 (v1.5.2)
- Downloading paragonie/random_compat (v9.99.100)
- Downloading paragonie/constant_time_encoding (v2.4.0)
- Downloading phpseclib/phpseclib (3.0.9)
- Downloading php-amqplib/php-amqplib (v3.0.0)
- Downloading phpmailer/phpmailer (v6.5.0)
- Downloading predis/predis (v1.1.7)
- Downloading rmccue/requests (v1.8.1)
- Downloading symfony/yaml (v4.4.26)
- Downloading tecnickcom/tcpdf (6.4.1)
- Downloading tightenco/ziggy (0.9.4)
- Downloading wpb/string-blade-compiler (6.0.3)
- Removing xjtuwangke/passwordhash (dev-master a7bcd97)
- Removing symfony/dotenv (v3.4.39)
- Removing symfony/debug (v4.4.7)
- Removing spatie/laravel-cors (1.3.3)
- Removing martinlindhe/laravel-vue-i18n-generator (0.1.46)
- Removing laravel/laravel (v5.8.35)
- Removing jakub-onderka/php-console-highlighter (v0.4)
- Removing jakub-onderka/php-console-color (v0.2)
- Removing erusev/parsedown (1.7.4)
- Removing dnoegel/php-xdg-base-dir (v0.1.1)
- Removing darkghosthunter/larapoke (v3.1.0)
- Downgrading amenadiel/jpgraph (3.6.21 => 3.6.14): Extracting archive
- Upgrading clue/socket-raw (v1.4.1 => v1.5.0): Extracting archive
- Upgrading dapphp/radius (2.5.4 => 2.5.5): Extracting archive
- Upgrading doctrine/event-manager (1.1.0 => 1.1.1): Extracting archive
- Installing doctrine/deprecations (v0.5.3): Extracting archive
- Upgrading doctrine/cache (1.10.0 => 2.0.3): Extracting archive
- Upgrading doctrine/dbal (v2.9.3 => 2.13.2): Extracting archive
- Upgrading doctrine/inflector (1.3.1 => 2.0.3): Extracting archive
- Upgrading doctrine/lexer (1.0.2 => 1.2.1): Extracting archive
- Upgrading symfony/polyfill-ctype (v1.15.0 => v1.23.0): Extracting archive
- Installing webmozart/assert (1.10.0): Extracting archive
- Upgrading dragonmantank/cron-expression (v2.3.0 => v3.1.0): Extracting archive
- Upgrading ezyang/htmlpurifier (v4.12.0 => v4.13.0): Extracting archive
- Installing voku/portable-ascii (1.5.6): Extracting archive
- Installing symfony/polyfill-php80 (v1.23.0): Extracting archive
- Upgrading symfony/polyfill-mbstring (v1.15.0 => v1.23.0): Extracting archive
- Upgrading phpoption/phpoption (1.7.3 => 1.7.5): Extracting archive
- Installing graham-campbell/result-type (v1.0.1): Extracting archive
- Upgrading vlucas/phpdotenv (v3.6.2 => v5.3.0): Extracting archive
- Upgrading symfony/css-selector (v4.4.7 => v5.3.0): Extracting archive
- Upgrading tijsverkoyen/css-to-inline-styles (2.2.2 => 2.2.3): Extracting archive
- Upgrading symfony/var-dumper (v4.4.7 => v5.3.3): Extracting archive
- Installing symfony/deprecation-contracts (v2.4.0): Extracting archive
- Upgrading symfony/routing (v4.4.7 => v5.3.0): Extracting archive
- Upgrading symfony/process (v4.4.7 => v5.3.2): Extracting archive
- Upgrading symfony/polyfill-php72 (v1.15.0 => v1.23.0): Extracting archive
- Installing symfony/polyfill-intl-normalizer (v1.23.0): Extracting archive
- Upgrading symfony/polyfill-intl-idn (v1.15.0 => v1.23.0): Extracting archive
- Upgrading symfony/mime (v4.4.7 => v5.3.2): Extracting archive
- Upgrading symfony/polyfill-php73 (v1.15.0 => v1.23.0): Extracting archive
- Upgrading symfony/http-foundation (v4.4.7 => v5.3.3): Extracting archive
- Installing symfony/http-client-contracts (v2.4.0): Extracting archive
- Installing psr/event-dispatcher (1.0.0): Extracting archive
- Upgrading symfony/event-dispatcher-contracts (v1.1.7 => v2.4.0): Extracting archive
- Upgrading symfony/event-dispatcher (v4.4.7 => v5.3.0): Extracting archive
- Upgrading psr/log (1.1.3 => 1.1.4): Extracting archive
- Upgrading symfony/error-handler (v4.4.7 => v5.3.3): Extracting archive
- Upgrading symfony/http-kernel (v4.4.7 => v5.3.3): Extracting archive
- Upgrading symfony/finder (v4.4.7 => v5.3.0): Extracting archive
- Installing symfony/polyfill-intl-grapheme (v1.23.0): Extracting archive
- Installing symfony/string (v5.3.3): Extracting archive
- Upgrading psr/container (1.0.0 => 1.1.1): Extracting archive
- Upgrading symfony/service-contracts (v1.1.8 => v2.4.0): Extracting archive
- Upgrading symfony/console (v4.4.7 => v5.3.2): Extracting archive
- Upgrading symfony/polyfill-iconv (v1.15.0 => v1.23.0): Extracting archive
- Upgrading egulias/email-validator (2.1.17 => 2.1.25): Extracting archive
- Upgrading swiftmailer/swiftmailer (v6.2.3 => v6.2.7): Extracting archive
- Installing ramsey/collection (1.1.3): Extracting archive
- Installing brick/math (0.9.2): Extracting archive
- Upgrading ramsey/uuid (3.9.3 => 4.1.1): Extracting archive
- Upgrading opis/closure (3.5.1 => 3.6.2): Extracting archive
- Upgrading symfony/translation-contracts (v1.1.7 => v2.4.0): Extracting archive
- Upgrading symfony/translation (v4.4.7 => v5.3.3): Extracting archive
- Upgrading nesbot/carbon (2.32.2 => 2.50.0): Extracting archive
- Upgrading monolog/monolog (1.25.3 => 2.3.0): Extracting archive
- Installing league/mime-type-detection (1.7.0): Extracting archive
- Upgrading league/flysystem (1.0.66 => 1.1.4): Extracting archive
- Installing league/commonmark (1.6.5): Extracting archive
- Upgrading laravel/framework (v5.8.37 => v8.49.2): Extracting archive
- Upgrading fico7489/laravel-pivot (3.0.4 => 3.0.7): Extracting archive
- Upgrading fideloper/proxy (4.3.0 => 4.4.1): Extracting archive
- Installing asm89/stack-cors (v2.0.3): Extracting archive
- Installing fruitcake/laravel-cors (v2.0.4): Extracting archive
- Installing jenssegers/model (v1.4.0): Extracting archive
- Installing genealabs/laravel-caffeine (8.0.0): Extracting archive
- Upgrading guzzlehttp/promises (v1.3.1 => 1.4.1): Extracting archive
- Installing psr/http-factory (1.0.1): Extracting archive
- Upgrading guzzlehttp/psr7 (1.6.1 => 2.0.0): Extracting archive
- Installing psr/http-client (1.0.1): Extracting archive
- Upgrading guzzlehttp/guzzle (6.5.2 => 7.3.0): Extracting archive
- Upgrading influxdb/influxdb-php (1.15.0 => 1.15.2): Extracting archive
- Installing justinrainbow/json-schema (5.2.11): Extracting archive
- Upgrading nikic/php-parser (v4.3.0 => v4.11.0): Extracting archive
- Upgrading psy/psysh (v0.9.12 => v0.10.8): Extracting archive
- Upgrading laravel/tinker (v1.0.10 => v2.6.1): Extracting archive
- Installing laravel/ui (v3.3.0): Extracting archive
- Installing librenms/laravel-vue-i18n-generator (0.1.47): Extracting archive
- Installing nunomaduro/laravel-console-summary (v1.7.1): Extracting archive
- Installing pear/net_dns2 (v1.5.2): Extracting archive
- Upgrading paragonie/random_compat (v9.99.99 => v9.99.100): Extracting archive
- Installing paragonie/constant_time_encoding (v2.4.0): Extracting archive
- Upgrading phpseclib/phpseclib (2.0.26 => 3.0.9): Extracting archive
- Upgrading php-amqplib/php-amqplib (v2.11.1 => v3.0.0): Extracting archive
- Upgrading phpmailer/phpmailer (v6.1.5 => v6.5.0): Extracting archive
- Installing predis/predis (v1.1.7): Extracting archive
- Upgrading rmccue/requests (v1.7.0 => v1.8.1): Extracting archive
- Upgrading symfony/yaml (v4.4.7 => v4.4.26): Extracting archive
- Upgrading tecnickcom/tcpdf (6.2.26 => 6.4.1): Extracting archive
- Upgrading tightenco/ziggy (v0.7.1 => 0.9.4): Extracting archive
- Upgrading wpb/string-blade-compiler (3.8.x-dev b3e340b => 6.0.3): Extracting archive
> Illuminate\Foundation\ComposerScripts::postAutoloadDump
> @php artisan package:discover --ansi
In Request.php line 334:
/framework/src/Illuminate/Foundation/Bootstrap/SetRequestForConsole.php on
line 32
Script @php artisan package:discover --ansi handling the post-autoload-dump event returned with error code 1
$ ./validate.php
line 32
PHP | 7.4.22
Python | 3.6.9
MySQL | ?
RRDTool | 1.7.0
Any help to fix the issue is deeply appreciated.
Thanks,
