Hi, I’m from the librenms project.
I’m not sure exactly what you want to be exported but that may not be the call you want to use.
http://docs.librenms.org/API/API-Docs/#api-route-10
Would provide you all the info for a device we have or http://docs.librenms.org/API/API-Docs/#api-route-21
which is used by oxidized to be a source for config management.
If we can help in anyway, give us a shout on irc freenode channel ##librenms.
Can we import fromJIRA to Librenms
Not sure what this is?
