@wriedel Sure, but I don’t really have an idea what you are talking about
Have a look at the code, I tried to make it easy to extend/understand.
Reposting from IRC:
$access_point_id
currently used? Also why is it sometimes $access_point_ip
?$entPhysicalIndex
I have LibreNMS running on my home network which has 2 Cisco ap1042n devices on it. These are multiple radio devices (1 gigabit Ethernet, 1 2.4GHz radio and 1 5GHz radio).
Happy to test anything out if you want to verify support for autonomous Cisco APs, although I doubt there are many people using them!
OK the noise floor graphs showed up after a while, maybe there wasn’t enough data to start with.
@TotalGriffLock if you are missing data, please create an issue on GitHub supplying the requested data and what you would like to see.
When I added Aruba IAP 325 virtual controller. I’m seeing these errors in the discovery process “ERROR: A sensor already exists at this index frequency-arubaos-iap-0” and its reporting over and over. not sure what is going on. Any help would be appreciated.
I think it’s trying to add the other AP’s radios but it can’t cause the radios are all named alike?
Discovery output: https://gist.github.com/kkrumm1/d21d2f15c579c69d9ef90db9d89e40e9#file-aruba-iap-discovery
