Hi all,
I am running into the issue that, when I add a new Rocky Linux 9.5 device into my LibreNMS, it shows up with the default Linux logo instead of the Rocky logo. I hope that you could help me out and let me know which information I need to share with you.
Kind regards,
Tom
Current result
Expected result
Output validation
[librenms@nms1-lab1 ~]$ ./validate.php
LibreNMS | 25.5.0 (2025-05-20T13:01:52+00:00)
DB Schema | 2025_05_03_152418_remove_invalid_sensor_classes (338)
PHP | 8.4.7
Python | 3.9.21
Database | MariaDB 11.7.2-MariaDB
RRDTool | 1.7.2
SNMP | 5.9.1
[OK] Redis is functional
